584,846 active members*
3,805 visitors online*
IndustryArena Forum > CAM Software > Alphacam > alphacam inventor import issue
Results 1 to 10 of 10
    Mar 2019
    4
    I am fairly new to alphacam and i am using it now to create basic programs for a cnc machine.
    But in the future we want to create more complex items.
    For this we want to use inventor to create the item then import it to alphacam to create the machine program.
    But when i try to import any file into alphacam it gives an error message "Failed to translate"
    Does anybody know why this happens.
    Or do i need to do something special with the inventor file?
    thanks
    Re: alphacam inventor import issue
    When you select "input cad" does it give a list of file types?
    The type of alphacam your using might be restricting to type of file you can insert
    May 2011
    108
    You just need to have the newest InventorWiever - it's free - AC uses this to convert .ipt files
    Mar 2019
    4
    When i try to select "input cad" it gives a whole list of options including inventor.
    Then when i select that it gives me the option to select the file.
    So i select an inventor part file (ipt) and click import.
    Then it gives me the error.
    I have Inventor 2019 and Inventor View 2019 Installed on the machine
    May 2011
    108
    Hi, try to upload a file to here - then it's easier to answer - we normally just use "drag and drop" from folder to AC - no problems..
    May 2011
    108
    Comes to my mind - but should not be a problem if You have Inventor, and not just the viewer? But the viewer 2019 needs viewer 2018 installed as well, as it misses some translators
    Mar 2019
    4
    I also tried to install inventor view 2018 but that also doesn't work
    add is a test file (just a simple block) that has been made in inventor 2019 and gives me the errors
    Attached Files Attached Files
    May 2011
    108
    Hi - I can't download your file?
    Mar 2019
    4
    thats weird since it just is a zip file with the inventor file in it
    it wont allow me to attach the inventor file direct
    i will add it once more here
    May 2011
    108
    Odd? I can download any other file from this forum - bur not Yours? Ill' try to send You a private note, with my e-mail - try to send it there.. ill look at the problem..
