585,954 active members*
4,396 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > FineLine Automation > Inductive Proximity Switch Mounting - Vertical vs. Horizontal
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Ntl Guest
    Re: Inductive Proximity Switch Mounting - Vertical vs. Horizontal
    So I did what you said and measured the inside of the spindle. And got 0.0008" not sure if that's exeptable definitely better than my first measurement of the end mill.
    I think the reason the first time it was so bad was the collet seat had a bunch of wood dust caked in it.
    I cleaned it out and rechecked the end mill shank and I was right at 0.001". I already bought the Techniks collets on Gerry's advise, but I still have the factory collet nut.
    So I don't know if I should be concerned about the left over run out or if it's close to what it should be. I never looked it up to see what it should be.
    Thanks guys for the info and sorry for getting away from the post topic.
    Dan
  2. #22
    Apr 2016
    841
    Quote Originally Posted by Ntl View Post
    Dan
    You hope for .00008" or better, but that is probably unattainable in cheaper Chinese routers. I guessing that spec is more applicable to metal mills than wood routers/spindles. Techniks standard collets are within .0002. They also have an ultra precision line, but I don't know the specs for it. For me, I don't have any instruments capable of measuring down to .00001. Probably safe to say that most hobbyists don't.
    I clean the collet and seat after each use. I clean again before starting a new project and when doing cutter changes. IMO, clean is king!
    Gary
  3. #23
    Ntl Guest
    Thanks Gary.
    Back to your sensors, what ever you do don't mount them on the gantry like I did on my y axis. It's very hard to adjust them unless I remove my motors, I should have thought about it before I mounted them. I just figured I'd do it the way Fineline does, but like I said it's a pain to adjust them. Granted you shouldn't have to do it a lot I would assume after you have it dialed. Just figured I'd let you know since I don't know how far you got with the machine you sent back.
    Dan
  4. #24
    Apr 2016
    841
    Thanks Gary.
    Dan
    Thanks for the tip, Dan. I'll keep your comments in mind when I get to the point of finalizing placement.
    Gary
Page 2 of 2 12
  1. Proximity switch mounting (home sensor)
    By joel0407 in forum DIY CNC Router Table Machines
    Last Post: 07-05-2017, 12:07 PM
  2. switch axis- transformation horizontal Z in vertical Z
    By Boettcher in forum HEIDENHAIN -> MillPlus
    Last Post: 11-02-2011, 04:09 PM
  3. Inductive proximity switches
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 09-03-2011, 12:54 AM
  4. Inductive Proximity Sensors
    By nickfox in forum CNC Machine Related Electronics
    Last Post: 09-07-2006, 03:15 AM
  5. Inductive Proximity Sensors-what are they?
    By Splint in forum CNC Machine Related Electronics
    Last Post: 08-01-2004, 11:24 PM
