Hello, I'll try to keep this as short and concise as possible. Problem:I have wired up the CNC, set the correct ports for my controller in MACH3 but can't calibrate the motors because they won't move when instructed.
Setup:
-Workbee CNC mechanical kit (openbuilds) https://www.aliexpress.com/store/pro...4e096319wVSxB7
-Electronics kit. Novusun. https://www.aliexpress.com/store/pro...73c62b00ZTExG2
-MACH3
-Makita router as spindle
Here's the wiring diagram i followed: https://bulkman3d.com/wp-content/upl...-BM3D-v1.2.pdf
Here's the manual for the controller kit https://bulkman3d.com/wp-content/upl...ware-Setup.pdf
Additional info: The controllers power up as expected, the motors freeze up as they should when in MACH3 and nothing else happens. I can't jog the machine or anything. When I attempt to motor calibrate the motor doesn't turn a bit.
I appreciate any type of help I can get and I'll provide more info if needed.
