585,996 active members*
4,222 visitors online*
    Top of part value in PP?
    I've tried part_height but that just yields zero all the time, I know that reference_plane is equal to Top of Part + Rapid Plane, I can live with a set Rapid Plane value if a hard coded subtraction can then be done in the PP to yield Top of Part, but none of my guesses at syntax have worked.
    Any ideas gents?
    TIA,
    Nick
    Re: Top of part value in PP?
    I've sorted out Advanced Posting for BCC V25 through to V29 so I'm just adding a tab to the drilling wizard with an input box allowing me to pass Top of Part directly to the VbScript in the PP
    Apr 2008
    1577
    I was digging around today in the documentation for V31 and stumbled upon this API call today.
    MILL_Get_TopOfPart() – API Only
    Mill Job
    Returns the top of feature value for the current feature.
    I haven't tried it but it looks promising. Trouble is I don't know what version this API call is valid for. But thought it was worth mentioning!
    Mastercam X9/2017 Multiaxis for SolidWorks - Bobcad V29 3ax Pro 4ax Std.
    Thanks for that!
    I'll see what that yields in V25 when I next delve into the PP
    Regards,
    Nick
  1. Replies: 0
    Last Post: 01-18-2019, 03:21 PM
  2. Replies: 2
    Last Post: 02-28-2016, 10:07 AM
  3. Replies: 1
    Last Post: 05-17-2015, 08:37 PM
  4. RFQ for part to mount on picatinny rail and sheetmetal part
    By JAW in forum RFQ (Request for Quote)
    Last Post: 08-23-2012, 02:00 PM
  5. Newb ? - CAD Part interference & mating part dims
    By pabmartin in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2009, 07:18 AM
