585,668 active members*
4,051 visitors online*
Thread: Making Parts
Results 1 to 9 of 9
    Jan 2007
    1332
    Making Parts
    Made 6.25" focuser parts today. 8.75" x 8.875" x 0.625" plate mounted in fixture with three MityBite XYZ pins
    Finding X Y datum using center tool on tooling ball
    Attachment 416416
    Finding Z datum using height tool #1
    Attachment 416418
    X Y Z axis zeroed
    Attachment 416420
    Fly cutting part to 1/2" thickness
    Attachment 416422
    Fly cut plate
    Attachment 416424
    Cutting out part using 1/2" endmill
    Attachment 416426
    Mar 2009
    1863
    Re: Making Parts
    Nice job Don. Don’t ya love these machines.
    Would be nice if they were 3 horsepower but I do just fine with 1.5. It just takes a little longer.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Jul 2011
    400
    Re: Making Parts
    Its nice to see how people set things up. I keep thinking I should set up some sort of a small fixture plate maybe about 8" by 8" as most of the stuff I want to make would fit on it. I'm still a beginner and find that figuring out how to hold and orient things is harder than actually programming the machine. Can you recommend a type of mitee bite that would be good to start out with?
    Jan 2007
    1332
    Re: Making Parts
    Quote Originally Posted by upnorth View Post
    I used mitee-bite locating pins to locate my fixtures on the mill bed. I bored two holes in the mill bed for two locating pins one round and one diamond shaped. https://www.miteebite.com/products/l...ns-and-liners/
    Attachment 416558
    Attachment 416560
    Mar 2009
    1863
    Re: Making Parts
    I don’t make big parts on my 1100. Actually, if I can’t hold a half dozen parts in one hand, they’re too big for me.
    Usually, when I design a fixture, I’ll design it to hold at least 4 parts and I design the fixture so one corner of that fixture is X zero Y zero. Then Z zero is the top of the part not the top of the stock.
    Jan 2007
    1332
    Re: Making Parts
    This part used every inch of Y travel so there was really no room on the 1100 for more than one of this part at a time. I don't like using a corner of the fixture as I use an edge finder that is not as accurate for me or as fast as using a tooling ball and center finder to find the X-Y datum. And for the angle fixture a tooling ball is definitely needed to locate the datum.
    Don
    Mar 2009
    1863
    Quote Originally Posted by Don Clement View Post
    Don
    I use the Mitutoyo 950-111 to set Z height and a Haimer for X and Y coordinates. I’ve had them both for close to 20 years.
    Apr 2013
    1788
    Re: Making Parts
    Quote Originally Posted by Steve Seebold View Post
    Two quick questions:
    I assume that your Haimer is a 3D Taster. If so, why not use it for Z in addition to X and Y?
    I've wondered about the internal design of the Mitutoyo 950-111. Does it use an internal inclined plane to translate the vertical movement of the top button to horizontal movement or something fancier?
    Jan 2007
    1332
    Re: Making Parts
    One has to touch the Mitutoyo 950-111 with a hardened tool to work? The thing I like about my tool #1 Z-height tool is that I measure the height of this tool offline on the surface plate in a Tormach fixture the same way as all the other tools. All other tool heights are relative to tool #1. That way when I find the Z-height by coming down on any surface such as a tooling ball on an angle fixture. Tool #1 also has plenty of over travel.
    Don
    Attachment 418332
  1. Videos of my old CHNC1 making parts.
    By nate in forum Hardinge Lathes
    Last Post: 03-16-2013, 08:52 AM
  2. Making rubber parts.
    By jaru-eri in forum DIY CNC Router Table Machines
    Last Post: 01-14-2011, 05:31 AM
  3. Making parts from polymers
    By chris123 in forum Uncategorised MetalWorking Machines
    Last Post: 08-17-2010, 01:07 PM
  4. Odd problem making parts
    By themedulla in forum Taig Mills / Lathes
    Last Post: 01-15-2010, 05:36 PM
  5. Where can I buy 4-5 Axis Wood CNC for making Car Parts ??
    By Calico in forum Commercial CNC Wood Routers
    Last Post: 02-28-2005, 02:21 AM
