585,987 active members*
4,436 visitors online*
    Jan 2017
    4
    Move without blocking other commands
    Is it possible to have one stepper (say X axis) turn all the time and execute the rest of the program without waiting until X is finished moving?
    I'm trying to use the X axis stepper of my machine on a 4th axis and thought it was kind of fun to see if i could use it as a lathe.
    Any advice would be very welcome!
    Grts,
    ApieVuist
    Jan 2017
    4
    Re: Move without blocking other commands
    Nobody?
    You will have to set it up as a PMC control axis. Not sure if the controller that you are using can support that. Fanuc does but you are going to have to use Fanuc motors and drives. How badly do you want it?
  1. CNC router suddenly stopped reacting to move commands
    By Venretus in forum Commercial CNC Wood Routers
    Last Post: 07-08-2017, 02:51 PM
  2. feedhold blocking move in either direction
    By Den095 in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-10-2016, 07:44 AM
  3. Moving Cin Arrow 500 (help blocking head?)
    By new2kit in forum Cincinnati CNC
    Last Post: 08-12-2011, 09:15 PM
  4. Parallel Port pin blocking?
    By farmallfan in forum Uncategorised CAM Discussion
    Last Post: 08-30-2006, 02:47 PM
