585,996 active members*
4,877 visitors online*
Results 1 to 6 of 6
    Mar 2013
    8
    PM 45 Z axis Linear bearings
    Hey guys, I wanted to share my linear bearing install/ upgrade on my grizzly PM 45 clone. I decided to do the linear bearings when I figured out the ways on the z where worn pretty badly. I had been trying to figure out why this mill always had a hard time with chatter. It turned out that the used mill wasn't taken care of too well and there was .020 ware toward the bottom of the ways. The linear bearings are HIWIN HGH25. I bought them from ebay new at a great price, around $200 bucks. So far I machined the z axis saddle and the ball nut mount. I then cut the dove tails just behind the top. I had to remove them to clear the new bearings and still be able to use the scrapped surface to mount the slides to. So far they are nice and smooth. I hope to pick up the z rapids to 100 ipm or more. Before I was only able to get it to 75 ipm.
    Attachment 416474Attachment 416470Attachment 416472Attachment 416476Attachment 416476Attachment 416478Attachment 416480
    Jun 2018
    84
    Re: PM 45 Z axis Linear bearings
    I'm liking what I see. Nice job! Please post more pictures and information on your mod as you progress.
    Feb 2012
    41
    Look like things are going well. Nice work so far keep us updated.
    Sent from my SM-N960U using Tapatalk
    Mar 2013
    8
    Here is an update videohttps://youtu.be/zEU7Rmwr6PI
    Aug 2006
    671
    looks great! Throw a counterweight or some air shocks on the head and you'll be able to bump up your rapids a bit more.
    I'd be interested to see a part machined before and after the upgrade. I know my surface finish improved a bit when I did mine, but I did all 3 axis at once so it's hard to say what was just from the Z axis.
    Also...what motor are you running on it? it looks to be fairly substantial and direct drive.
    Mar 2013
    8
    I had gas shocks on it before the upgrade. They didn't do much so I left them off. I am running a 4025 oz/in stepper on the z. The driver for it is a bit bigger then the 3hp vfd running the spindle.
    The surface finishes had improved quite a bit. I haven't really run the machine a whole lot yet. Just to make parts for the ATC I am building for it. I will be making some parts for a vw tdi swap I am starting. machining the fly wheel and adapter plate should be fun.
  1. ZZ-Axis Linear Bearings VS ways
    By new2cnc4 in forum Novakon
    Last Post: 02-10-2016, 05:43 PM
  2. momus with linear rails/ linear bearings- Any one tried?
    By sa7o in forum Momus Design CNC plans
    Last Post: 07-11-2014, 08:23 AM
  3. Very sloppy linear bearings on Z axis, Please Help!!
    By Ranscon in forum Linear and Rotary Motion
    Last Post: 11-11-2010, 02:19 AM
  4. Z axis linear bearings for MDF router
    By martinw in forum Linear and Rotary Motion
    Last Post: 10-28-2007, 10:18 PM
  5. skate bearings versus linear bearings
    By paul langwade in forum Linear and Rotary Motion
    Last Post: 05-29-2006, 04:06 PM
