585,996 active members*
4,626 visitors online*
    Oct 2014
    10
    Gecko G540 + SmoothStepper with mach4
    Hi, I've been trying to setup a CNC router with Mach4 , It was previously being controlled with a gecko g540 and Linuxcnc But now I'm trying to set it up with a Ethernet smoothstepper + g540 and Mach 4 on Windows 10 . When I power the system the motors lock like normal and when I load a gcode and click cycle start the motors start making noise as if running the code but they don't move . Any help would be appreciated
    Oct 2016
    10
    Re: Gecko G540 + SmoothStepper with mach4
    I'm not familiar with your controllers but it sounds like your steppers are stalling.
    Try lowering the acceleration in the motor configuration. If that works, work your way up again to find where they begin to stall and stay well below that acceleration level.
    If they start moving but only a little bit you may need to lower your velocity.
    If you have a problem with velocity or acceleration it might be easier to isolate the problem by jogging the axes manually.
  1. Mach4 to Ethernet SmoothStepper Motion Control Board to Gecko G540
    By SteveS in forum Automation Technology Products
    Last Post: 11-19-2015, 01:56 AM
  2. Warp9 Ethernet smoothstepper with a G540 and MACH4 troubleshooting
    By zoomak in forum Machines running Mach Software
    Last Post: 06-21-2015, 11:34 PM
  3. Gecko G540 with Mach4 + USB or NOT
    By jasoneule in forum Mach Software (ArtSoft software)
    Last Post: 04-06-2015, 12:25 AM
  4. Gecko g540 and SmoothStepper USB
    By mikenz in forum Gecko Drives
    Last Post: 05-28-2013, 11:10 PM
  5. gecko g540 and smoothstepper
    By pabney in forum Gecko Drives
    Last Post: 08-01-2012, 10:42 PM
