585,568 active members*
3,288 visitors online*
Results 1 to 3 of 3
    Apr 2019
    4
    RFQ laser cut 3mm or 1/8in brass or aluminum
    prototyping a project, can do all of it myself except for this piece. final version i want to be out of brass, but for the prototype im sure aluminum or steel will be cheaper and sufficient
    laser cutting was the most obvious process to me, but other methods are fine, just needs to be relatively dimensionally accurate and flat.
    dimensions are 15.25" x 6.25", thickness can be either 3mm or 1/8 in (i imagine the latter is more likely to be on hand and thus cheaper, but if 3mm is a bit less that works too)
    not time sensitive at all
    May 2003
    323
    Re: RFQ laser cut 3mm or 1/8in brass or aluminum
    Your Dm is disabled.
    Sent from my MHA-L29 using Tapatalk
    Apr 2019
    4
    thanks for the heads up, fixed
  1. Smallish aluminum and brass pieces
    By Erik D_lux in forum North America RFQ's
    Last Post: 06-14-2017, 05:27 PM
  2. RPM? Brass Aluminum
    By Greenworks in forum Haas Lathes
    Last Post: 04-20-2016, 07:36 PM
  3. RFQ - 29 part Brass or Aluminum
    By giff in forum RFQ (Request for Quote)
    Last Post: 11-14-2013, 08:32 PM
  4. aluminum and brass
    By azureskys in forum Casting Metals
    Last Post: 03-13-2010, 06:23 PM
