585,927 active members*
3,433 visitors online*
Thread: Multi Axes
    Apr 2009
    3376
    Multi Axes
    So I am inquiring responses from those that bought the Multi Axes Tool Path add on
    I keep getting jobs that if I even did have a 5 axis trunnion,The length of part would be a no go.And I don't have a trunnion.
    The image is just a representation of similiar situations I am trying to solve,Length of part and quantity of parts make fixturing impractical
    So,in my mind the logical solution is the multi axis add on,,,I am using V28
    Thinking Lollypop cutter
    You can see from the image,I need to have a 3D toolpath that will undercut
    Looking to replies of people who have purchased this add on and actually used it in real life part making
    TY
    Apr 2009
    3376
    Re: Multi Axes
    Also,actual tool shape,,I have a cutter grinder and make my own to work
    Apr 2008
    1577
    Re: Multi Axes
    I've demoed the BobCAD multi-axis and if you encounter (or expect to encounter) a lot of this you're going to find the additional toolpaths invaluable. I have them in my "other" software and I use them in 3 axis output more than I use them for full 5 axis output. It's ModuleWorks as you probably already know and a lot of different software products use it and BobCAD puts their own flavor on it but at the core it's the same great ModuleWorks toolpath.
    You're going to use some of these toolpaths on parts that don't have undercuts because they are easier to use or offer a better surface finish. One of these days I'll get them added to my BobCAD toolbox but I'm just using what I have. I got the "other" software as part of a package deal with my 5 axis Haas.
    Mastercam X9/2017 Multiaxis for SolidWorks - Bobcad V29 3ax Pro 4ax Std.
  1. Gibbscam postprocessor for multi axes for has
    By eldonkike in forum Post Processor Files
    Last Post: 07-06-2018, 04:16 AM
  2. Multi Axes
    By cncadmin in forum DIY CNC Router Table Machines
    Last Post: 04-23-2017, 10:59 AM
  3. Need help - two slave axes of two main axes?
    By georgem in forum Mach Software (ArtSoft software)
    Last Post: 11-17-2015, 03:04 AM
  4. Multi Pass multi-insane?
    By Injuhneer in forum Mach Wizards, Macros, & Addons
    Last Post: 07-13-2014, 02:33 AM
