585,996 active members*
4,154 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Old horizontal mill conversion-thoughts and advise
    Jan 2019
    10
    Hi to all,
    Recently got old sturdy horizontal mill, approx dimensions about 60x60x60 cm, sturdy column and complete cast iron, hravy one, about 100 kg...
    Will convert it to vertical mill firat and add closed loop steppers, ballscrews etc.
    As first consideration, wouls like to hear your opinion:
    I intend to put thick metal plates (12-15mm) on all axis and put linear rails on top of plates. What would be proper size, I think to use hgh20? Also, I will make a new saddle and new casting iron head mount for vertical spindle...
    Going with plates makes me easier to align rails, ensure parallelism and squareness, since plates will be machined on CNC, so the saddle too.
    Will fix them on top of vee grooves...
    Here are few pics. More pics later.
    Thanx in advance!
    Sent from my LG-D855 using Tapatalk
    Jan 2019
    10
    Re: Old horizontal mill conversion-thoughts and advise
    Here are few more pics
  1. Thoughts on conversion kits for PM-25MV?
    By Change in forum Benchtop Machines
    Last Post: 08-23-2018, 02:20 PM
  2. DM2400 conversion to horizontal mill
    By cyclotron in forum Dyna Mechtronics
    Last Post: 05-12-2014, 09:26 PM
  3. Conversion of Dyna2400 to horizontal mill and mach3
    By cyclotron in forum Vertical Mill, Lathe Project Log
    Last Post: 02-05-2014, 01:32 AM
  4. Looking for some advise on X2 Conversion.
    By chbm in forum Benchtop Machines
    Last Post: 12-19-2012, 04:03 AM
  5. Knee Mill CNC Conversion- Your thoughts???
    By Syil_Australia in forum Knee Vertical Mills
    Last Post: 12-27-2007, 11:28 AM
