pls, how to remove the beep sound, when pressing a key or touching the screen ? kindly
The quick fix
https://www.duckbrand.com/
Disconnect the speaker.
Ben
Sent from my E6810 using Tapatalk
hello, i opened the panel, and there was a black thing : i put some kind of taper on it, and now is more silent ... still bipping, but less
i don't know if i can disconnect it : should i rip it off from the green board ?
a while ago, on the lb lathe, i could disable the sound for keypress or screen touch ( only one, not both ), by messing with a setting, but i forgot / kindly
Most speakers have a 2 wire plug going to them that can just be unplugged. Is the speaker mounted directly on a circuit board. A picture might help determine the best way to unhook it. As for disabling in software sorry I can't help you there. The suggestion to unhook the speaker does not come from experience with okuma machines. I have done so on a hurco, and Haas though for the same reason.
Ben
hy bhurts, it will take a while to find a camera, since i trashed mine a while ±ago ...
i connect with teamviewer on the machine, and it bips like crazy into operator's head / kindly
The black thing is called a Piezo Speaker
https://en.wikipedia.org/wiki/Piezoelectric_speaker
No. might damage the PCB.
maybe ... but i will take a photo beforeNo. might damage the PCB
looks similar .... i can't see the cables; it's round & black, with a hole on it, and through the hole can be seen some metal part : i just filled that hole with stuffThe black thing is called a Piezo Speaker
looks like attached thing, and it is on the green circuit bord and near it is a blue button, that messed up the controller when i pressed it ... but there was another blue one, pressed also that, and i could not turn off the controller, and at next restart it could not back-up, but after another restart it was all back to " normal "
Find beep.exe file and change filename
"Imagination is more important than knowledge."
hy kurmay, there is no beep.exe; if i search " beep ", i find attached; i clicked that *.bat, but nadda ... mmm
