584,874 active members*
5,234 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > pls, how to remove the beep sound, when pressing a key or touching the screen ?
Results 1 to 11 of 11
    Jun 2015
    4131
    pls, how to remove the beep sound, when pressing a key or touching the screen ? kindly
    Aug 2009
    1567
    Re: pls, how to remove the beep sound, when pressing a key or touching the screen ?
    Jun 2013
    1041
    Disconnect the speaker.
    Ben
    Sent from my E6810 using Tapatalk
    Jun 2015
    4131
    hello, i opened the panel, and there was a black thing : i put some kind of taper on it, and now is more silent ... still bipping, but less
    i don't know if i can disconnect it : should i rip it off from the green board ?
    a while ago, on the lb lathe, i could disable the sound for keypress or screen touch ( only one, not both ), by messing with a setting, but i forgot / kindly
    Jun 2013
    1041
    Most speakers have a 2 wire plug going to them that can just be unplugged. Is the speaker mounted directly on a circuit board. A picture might help determine the best way to unhook it. As for disabling in software sorry I can't help you there. The suggestion to unhook the speaker does not come from experience with okuma machines. I have done so on a hurco, and Haas though for the same reason.
    Ben
    Jun 2015
    4131
    hy bhurts, it will take a while to find a camera, since i trashed mine a while ±ago ...
    i connect with teamviewer on the machine, and it bips like crazy into operator's head / kindly
    Aug 2009
    1567
    The black thing is called a Piezo Speaker
    https://en.wikipedia.org/wiki/Piezoelectric_speaker
    Quote Originally Posted by deadlykitten View Post
    No. might damage the PCB.
    Jun 2015
    4131
    maybe ... but i will take a photo before
    looks similar .... i can't see the cables; it's round & black, with a hole on it, and through the hole can be seen some metal part : i just filled that hole with stuff
    Jun 2015
    4131
    looks like attached thing, and it is on the green circuit bord and near it is a blue button, that messed up the controller when i pressed it ... but there was another blue one, pressed also that, and i could not turn off the controller, and at next restart it could not back-up, but after another restart it was all back to " normal "
    Aug 2011
    418
    Find beep.exe file and change filename
    "Imagination is more important than knowledge."
    Jun 2015
    4131
    hy kurmay, there is no beep.exe; if i search " beep ", i find attached; i clicked that *.bat, but nadda ... mmm
  1. Replies: 1
    Last Post: 05-20-2020, 01:56 PM
  2. Replies: 1
    Last Post: 02-05-2018, 07:46 PM
  3. LC6090 stuck on startup screen, thud sound from machine
    By indrora in forum Commercial Laser
    Last Post: 03-12-2014, 07:17 AM
  4. Mach3 New Install MDI Screen Pressing X Jumps to DRO
    By cjjonesarmory in forum Mach Software (ArtSoft software)
    Last Post: 12-21-2011, 06:31 PM
  5. Beep Volume
    By musall37 in forum Haas Mills
    Last Post: 03-09-2010, 10:15 PM
