585,933 active members*
3,818 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal 4020 Moving-measurements needed
Results 1 to 6 of 6
    Mar 2019
    12
    Question Fadal 4020 Moving-measurements needed
    Hey guys,
    Looked around best I could and in the manuals, but what is the distance between the removable forklift panels on the front of the machine to slide the forks through?? Reason I ask is that we may use a front end loader and his forks can only locate I believe in one spot.
    Anyways, was hoping someone had a minute and could run a tape on center of each panel to let me know. The logistics of a move is quite the headache. Will make a nice thread later with pics of how I chose to do it with finer details. I already have the steel square tubing to slide through the casting fyi.
    BTW- 96 Fadal with Extended Z FTW
    PS- I am a long time lurker and member of other boards, so not necessarily a newbie. Plan to stick around..
    Thanks!
    Aug 2009
    1573
    Re: Fadal 4020 Moving-measurements needed
    Looks like about 41" between centers of 15" x 7 1/2" Sheet metal holes. Measurements from a 2005 Fadal 4020
    Jan 2010
    321
    I have the exact same machine as yours.
    I will check later
    Mar 2019
    12
    Thanks guys! Much appreciated!
    Jan 2010
    321
    Centre to centre 104cm
    Casting is 68cm approx so you would need that measurement between the forks
    Oct 2008
    1632
    If your forks are slightly wider than the cutouts then realize that front sheet metal skirt comes off pretty easy. Too narrow then you're out of luck.!
    Good luck with the move! LOL, I just noticed the date so hopefully you got it safely into position.
    Richard
    Quote Originally Posted by HalfRapid View Post
    Hey guys,
    Thanks!
  1. Fadal VMC 15 measurements needed please
    By Rob21tq in forum Fadal
    Last Post: 04-05-2018, 10:47 PM
  2. Replies: 4
    Last Post: 02-07-2018, 05:25 PM
  3. A Few Measurements Needed...
    By SCzEngrgGroup in forum Tormach Personal CNC Mill
    Last Post: 01-30-2013, 01:15 AM
  4. Fadal 4525 & 4020 Parts Needed
    By rtrading in forum Want To Buy...Need help!
    Last Post: 08-07-2012, 11:29 PM
  5. Fadal 4020 mm/um in MDI
    By hartan in forum Fadal
    Last Post: 12-20-2011, 10:50 AM
