585,883 active members*
4,924 visitors online*
Results 1 to 8 of 8
    Nov 2014
    14
    Looking for advise on cutting thin paper/fabric material
    I'm new to laser cutting and have a question with regards to cutting power and feed/speeds. I'm trying to cut a lightweight synetic fabric material with a 7w diode based laser. I have currently set around 12.5% cutting at 5 inches per min. Results are okay but there is some yellowing around the edges. Would you suggest upping the power/cut speed or retarding it? Is there a general ratio of wattage change to speed feeds?
    Re: Looking for advise on cutting thin paper/fabric material
    I'm not familiar with this particular setup but, 5" per min is really slow. Increase your speed to max. If it is not cutting through the material at max feed rate, increase power until it does. If it is cutting through at max feed rate, reduce power if you are still getting the yellowing.
    Also, check the focus of your diode to make sure it is at the smallest focus point possible. Focus on black paper & use a magnifying glass to help see the dot. You want it focused as close to the size of a pin prick as possible.
    One of my lasers is only a 3 watt & I engrave wood at waay faster speeds.
    Hope this helps.
    Sent from my SM-G935F using Tapatalk
    Nov 2014
    14
    Thanks for the info. I'm only running the laser at 12.5% power so about 1watt. I'll increase it as well as the speed and see what happens. As a reference when you're engraving wood how fast do you run the laser and are you at full power? Since i'm new to this I don't have a good handle on the relationship of cut speed vs power.
    I don't recall exactly the power & speed I was using. It's been awhile since i used it. It's a handy little open bottom laser. Great for engraving on cutting boards & such. I think 45-70% power & 80-100% feed rate.
    The only numbers I have in my head at the moment are for a 50 watt Co2 that I run at 45% & 300mms(1 foot per second) engraving acrylic panels & pendants.
    May 2015
    1422
    Also be aware that the yellowing may just be a fact of life when laser cutting that material. You may calm it down by running hotter and faster which gives less time for the heat of the cut to propagate into the material from the edge, but it may not go away completely. Might find you're better off with a drag knife setup.
    Nov 2014
    14
    Thanks all.
    Nov 2015
    371
    Quote Originally Posted by lordhelemt View Post
    To avoid the yellowing of the edges you have to cut with 600-1000mm/s (depending on the type of paper). To penetrate the material in one pass at that speed typically requires 60-100W laser power.
    In short, you need a different machine. The ones specialized for paper are very expensive.
    If you need to cut paper without yellowing around the edges , it is better to use galvo model . It can get clean cutting edge even on white paper .
    Many thanks .
    Kelvin
  1. JD 6090 Laser stopped cutting through thin material - help
    By Mmisterbungl in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-12-2016, 12:11 AM
  2. Laser Engraving and Cutting Machine for clothes, paper, fabric and wood
    By aaronhernandez99 in forum Laser Control Software
    Last Post: 12-15-2015, 12:12 PM
  3. thin plastic material for engraving
    By monkeyfist in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-16-2015, 09:39 PM
  4. Need advise and help to purchase a laser for cutting thin metal
    By hive8 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-12-2015, 07:54 AM
  5. holding thin material on lathe
    By 40fordcoupe in forum MetalWork Discussion
    Last Post: 08-24-2011, 04:08 AM
