584,817 active members*
5,103 visitors online*
Results 1 to 3 of 3
    Apr 2012
    79
    Tornado 100 Turret Overheat
    Hi
    I have a tornado 100 which keeps coming up with a Turret Overheat alarm. It used to just happen when I first turned on the machine and I had to turn it off and on again to clear the alarm but now it is doing it randomly during the day and I have to wait an hour for it to clear. I have read through this forum and it suggests changing the control relays but I am unsure which ones they are as when I do index the turret and I cannot see any relays moving in the cabinet. Anybody have any ideas please as the turret does not seem to be getting warm at all so dont think it is the turret jamming or getting tight.
    Aug 2009
    1566
    Re: Tornado 100 Turret Overheat
    check all wiring to turret...low voltage connectors unplug n plug back in.
    Apr 2012
    79
    Hi, Thanks for your help. I have checked the voltage through the Overheat Sensor and when disconnected it is 21.6volts. Is this classed as low? I am unable to check the solenoid voltage yet as my multimeter is not quick enough to get a reading during the tool change so I will order a new one that will record a max value.
  1. Tornado 300 Duplomatic Turret
    By yarpo in forum Colchester Tornado lathes
    Last Post: 06-10-2021, 04:24 PM
  2. Tornado 100 Duplomatic turret and parameter problem
    By bezelchuck in forum Colchester Tornado lathes
    Last Post: 12-29-2013, 10:23 PM
  3. Stuck turret button ON CNC Colchester Tornado 100.
    By sp8rt1cus in forum Colchester Tornado lathes
    Last Post: 04-03-2013, 09:52 PM
  4. Colchester Tornado 300 with misaligned turret
    By Andreas_H in forum Colchester Tornado lathes
    Last Post: 02-23-2011, 05:37 PM
  5. Tornado 300, Alarm AL1018 Turret to slow
    By kama in forum Colchester Tornado lathes
    Last Post: 11-09-2009, 02:56 PM
