585,883 active members*
5,169 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Fusion 360 Drag Knife Add On Available!!!
    After several months of development and testing we have finished a drag knife add-on for Fusion 360. This add-on creates support for the use of drag knives. Users will now have the ability to generate drag knife specific tool paths from within Fusion 360 after installing the add- on.
    Features include the ability to specify swivel height, blade offset and corner tolerance angle. The Drag Knife add-on also supports multiple depth passes. The drag knife add-on is compatible with both OSx and PC versions of Fusion 360.The add-on comes with comprehensive documentation as well as a video to assist users in their workflow.
    The Drag Knife add on can be downloaded from the Fusion 360 App store.
    (https://apps.autodesk.com/FUSION/en/Home/Index)
    It is recommended that users also download and install the free NC Viewer add-on from the Fusion 360 App Store or use the online version which can be found at https://ncviewer.com .
    Apr 2021
    Re: Fusion 360 Drag Knife Add On Available!!!
    A drag-able forum is designed for the wonders of the world. the approach of the https://www.meldium.com/12-real-worl...erful-article/ is rushed for the standing aims. The skills are fit for the hopeful goals for the inductive policy for the fearful ending of the forums.
  1. using a drag knife
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 05-10-2021, 12:03 PM
  2. Fusion 360 Drag Knife Add On software!!
    By WhiteRoom in forum Autodesk
    Last Post: 04-02-2019, 11:24 AM
  3. Fusion 360 Drag Knife Software Add On!!
    By WhiteRoom in forum Autodesk CAM
    Last Post: 04-02-2019, 11:21 AM
  4. Fusion 360 Drag Knife Software Add On
    By WhiteRoom in forum For Sale Only
    Last Post: 04-02-2019, 11:17 AM
