585,556 active members*
3,562 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > changing Huanyang GT VFD
    Mar 2018
    54
    I had this posted on the wrong forum for a couple of days so i changed it a bit,
    after already changing the invert-er one time because it failed, again I need to replace or repair it. Because it is still under warranty it was replaced with the "GT" model? {recomended by Huanyang) So after installing it I opened the manual to program it only to find it is completely different than the previous 2 Invert-ers from Huanyang. I now have the spindle running from the key pad on the invert-er but not through mach3/ RS485 plugin. As i said this link was on the wrong forum but when it was on the wrong forum, Gerry said that there might be a problem with the plugin and that I needed an ModBus plugin? Now i am getting even further into the woods...If I am to install a ModBus plugin
    1 - do I still use the RS485 USB ? or is there something else I need to get ,
    2 - if I am to use this RS485 USB do i remove the plugin for this and add the ModBus plugin into mach3
    3 - and lastly where will i find this ModBus plugin for Mach3 run from windows 7 PC and parrallel port DB25 cable
    Pat
    Mar 2010
    813
    Re: changing Huanyang GT VFD
    Mach3 has a it's own serial Modbus setup.
    yes you will still need your RS485 converter and will need to remove the old Huanyang plugin
    It's not a plugin in Mach3.
    Under Function Cfg > Setup Serial Modbus.
    You'll need to learn how Modbus works, and how to set it up.
  1. Huanyang VFD - again
    By sffarm in forum Spindles / VFD
    Last Post: 03-15-2017, 04:39 AM
  2. Huanyang VFD
    By dwschool in forum Mach Lathe
    Last Post: 02-06-2013, 05:40 PM
  3. Huanyang VFD
    By moonman5 in forum Phase Converters
    Last Post: 01-19-2013, 05:43 AM
  4. Help changing PD values in a Huanyang
    By BanduraMaker in forum Phase Converters
    Last Post: 03-06-2012, 04:28 AM
