585,996 active members*
4,502 visitors online*
Page 3 of 3 123
Results 41 to 53 of 53
  1. #41
    Aug 2010
    686
    Re: CNC Construction Set Build 3 Blog
    Volume 5 - Chapter 5 - Table Slats
    Table slats are cut and installed.
    Attachment 417166
    The slats are held in-place with standoffs.
    Attachment 417168
    These standoffs, can be replaced as need as they are considered consumables. This means you can add/move/remove as you see fit. Note that they also become mounting points for fixtures.
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
  2. #42
    Aug 2010
    686
    Volume 5 - Chapter 6 - Downdraft Shelf
    The cement board shelf is installed.
    Attachment 417172
    Volume 5 - Chapter 7 - Downdraft Side Panels
    Downdraft sides installed.
    Attachment 417174
    Volume 5 - Chapter 8 - Downdraft End Panels
    The end panels have been added. Its time to mount the torch.
  3. #43
    Aug 2010
    686
    Volume 5 - Chapter 9 - Torch Holder
    Everlast IP-60 torch holder installed.
    Attachment 417178
    Torch holder parts walk-through.
    Everlast iPT60 Tool Holder — Kronos Robotics
  4. #44
    Aug 2010
    686
    Heavy Duty Table
    It was at this point that I decided to make a heavy duty aluminum table insert that could be used for milling operations.
    Attachment 417182
    These support brackets must be placed so that they fall between the slats.
    Attachment 417184
    To further support the table, small bolts or studs can be inserted into some of the standoffs.
    The writeup for this table can be found here:
    https://www.kronosrobotics.com/heavy...aluminum-table
  5. #45
    Aug 2010
    686
    Volume 5 - Chapter 10 - Everlast Control Cable
    Control cable complete.
    Attachment 417186
    With the control cable we can get the following signals from the plasma cutter to the CNC.
    ARC Start
    ARC OK
    Torch Voltage (Divided)
  6. #46
    Aug 2010
    686
    Volume 5 - Chapter 11 - Mounting the Relay
    I originally was going to use this relay board to start and stop the plasma cutter. But, due to some safety issues with the relays activating while powering up, I decided against the.
    Attachment 417188
    I decided on this Omron LY2 style relay. They are easy to replace and there are tons of manufactures that sell them.
    Attachment 417190
  7. #47
    Aug 2010
    686
    Volume 5 - Chapter 13 - Cable Hookup
    Cable connected and wired to the relay and G540.
    Attachment 417192
    Volume 5 - Chapter 14 - Configuration
    Mach3 is now configured. At this point we can turn the torch on and off. It's time for a test.
  8. #48
    Aug 2010
    686
    Volume 5 - Chapter 15 - Torch Test
    Fire that torch.
    Attachment 417196
  9. #49
    Aug 2010
    686
    Volume 5 - Chapter 16 - Conclusion
    The torch fires perfectly. But before I can actually cut anything we have to get our downdraft up and running. These will be covered in separate articles, that I will link to once they have been posted.
    Volume 5 is now complete
  10. #50
    Aug 2010
    686
    Air quality is as important as air quantity when it comes to plasma cnc.
    I did a write up on the air requirements for the Everlast 50s plasma cutter and the CNCCS.
    See it here:
    Plasma CNC Air Quality
  11. #51
    Aug 2010
    686
    I added a downdraft exhaust collar to the downdraft enclosure.
    Attachment 417690
    See the full write up here:
    Downdraft Exhaust Collar — Kronos Robotics
  12. #52
    Aug 2010
    686
    I added the downdraft vent to my system.
    Attachment 417760
    See the writeup here:
    Downdraft Vent — Kronos Robotics
  13. #53
    Aug 2010
    686
    I added a some brackets to help with eliminating plasma dust in the shop.
    Attachment 418108
    You can see the full write-up here:
    https://www.kronosrobotics.com/cnccsdust1
Page 3 of 3 123
  1. Replies: 35
    Last Post: 03-13-2018, 03:41 AM
  2. New Design/Build: CNC router (steel plate construction) + Raspberry Pi
    By cmadki4 in forum DIY CNC Router Table Machines
    Last Post: 09-24-2017, 03:11 PM
  3. Replies: 4
    Last Post: 07-24-2013, 11:48 AM
  4. DIYLILCNC PVC Build - Bed Construction
    By jimmycakes in forum DIY CNC Router Table Machines
    Last Post: 12-10-2010, 05:58 PM
  5. 9'X5.5' Router table - Build Blog...
    By turbotoys in forum DIY CNC Router Table Machines
    Last Post: 09-13-2007, 04:20 PM
