585,973 active members*
3,945 visitors online*
IndustryArena Forum > CAM Software > CutLeader > postprocessor for START/ FANGLING control
    Sep 2011
    110
    START and FANGLING cnc control are used widely on plasma/oxy cutting machine, we made some modification in the postprocessor to support both control, user could set the code string in NC configuration directly to define the code format.
    More features/options could be added further to make the default postprocessor powerfule and flexible. Just as what we did for Mach3 and linux CNC control.
    Here is the options we added at present.
Name:	nc options.jpg
    Re: postprocessor for START/ FANGLING control
    thanks for this post, please forgive my ignorance am a newbie.... how do i navigate to the NC CONFIG window.
    Sep 2011
    110
    Quote Originally Posted by ibrahimwrites View Post
    CutLeader-->Menu Configuration-->Expert Library-->Configuration-->NC Config
  1. Mid-program start on 640M control?
    By byoungDTS in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-06-2018, 07:09 PM
  2. Lathe Postprocessor for Siemens Control
    By mecheng10 in forum SprutCAM
    Last Post: 11-10-2012, 05:19 PM
  3. Replies: 4
    Last Post: 01-06-2009, 05:20 PM
  4. Help - Spindle Will Not Start from NC Control
    By CSE in forum Bridgeport / Hardinge Mills
    Last Post: 05-24-2006, 05:56 PM
