585,885 active members*
6,308 visitors online*
    Sep 2006
    120
    Anilam 5000 boot problem
    Hi I’m helping a friend who recently bought a knee mill with an Anilam 5000 control. It seemed to work ok at first except it often didn’t seem to turn on, but usually cycling the power brought it back. Then he moved it to another workshop, I thought it may be a bad connection somewhere so I re-seated all the cards and connectors. Then I plugged it in and it didn’t turn on at all. In fact, when the control on/off switch was turned, a lamp on the other side of the room went on and off! . As it happens, there was a phase down in the supply.
    Anyway, whether the problem was already present, was caused by the transport, or due to the electrical supply, the control either hangs during bios boot, or begins to load dos but immediately returns to a command prompt with an “Abnormal Program Termination- Memory Protection Fault”
    I originally thought the erratic booting may be due to a failing hdd so I cloned the original but it does the same thing with the new drive. Has the machine software been corrupted? Or could it be the RAM?
    Anilam has gone now, is there somewhere we can get hold of a copy of the control software? We have 2 floppies but they’re the offline programming stuff.
    I’d be grateful for any advice!
    Aug 2009
    1573
    Re: Anilam 5000 boot problem
    Wild guess...bad RAM on motherboard another thing to start checking is Power Supply's outputs.
    Jun 2019
    10
    Have you changed the cmos battery? my aniklam 4200t was doing all kind of strange things, then one day it wouldn't boot up, changed the cmos battery and reset the bios settings and its been fine since.
    Jan 2019
    It could be done many ways. Try it with optimization next time: https://thinkmobiles.com/products/pc...tion-software/ Works much smoother for me now that I've done it.
    Sep 2019
    Hi everyone
    sorry to hijack this post. i cant seem to find where i can
    post my own.
    i have a megamill with a anilam 5000m control
    when i power up the machine all 3 axis creep and i cant get the machine
    to home. i really need some help with this.
    it seems no one in South Africa can help me.
    Best regards
    Mike Oram
  1. CW 5000 chiller problem
    By Ido in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-14-2019, 01:23 PM
  2. Anilam Crusader M 3 Axis Mill will not boot up.
    By Sierevello in forum CNC Machine Related Electronics
    Last Post: 10-23-2018, 04:31 PM
  3. problem with aciera f45 cnc 5000
    By don shone in forum Uncategorised MetalWorking Machines
    Last Post: 09-29-2015, 07:39 PM
  4. Anilam 3300MK Boot Disk
    By klingnic in forum Controller & Computer Solutions
    Last Post: 04-13-2011, 03:50 AM
  5. Anilam 5000 Motion Control Card Fault
    By Eighteenten in forum Controller Cards
    Last Post: 12-09-2010, 08:13 PM
