Re: Bobcad v31 Post issues mach3
Looking closer at the code, it just looks a little weird. The arc moves have a very large radius (230) and a relatively small chord length with a weird 0.0029" linear move in between them. I think the geometry is suspect but I can't say without seeing it.
Can you check one other thing and see what the answer to these questions are in your post?
319. Break Arcs with Radius Larger than? 9999.9999
320. Arc segment breaking tolerance? 0.001
321. Line segment max length? 999.99
554. Convert small arcs to lines (arc length to be specified in block 555.)? n
555. Small arc length to break? 0.0025
Originally Posted by
Brad777
So I thought that it would just be easier if I just posted the code to look at. I see a g64 but nothing else.
O0100 (BOBCAD GCODE TEST.NC)
( DATE-SUN. 04/07/2019 ,TIME-08:34AM)
( POST- Mach3 )
Y-2.5951
X2.4091 Y-2.4757
X2.409 Y-2.4756
X2.3995 Y-2.4658
Y-2.4629
G02 X2.2745 Y-2.3336 I167.7055 J157.5456
G01 Y-2.3365
G02 X2.1495 Y-2.2071 I167.5702 J157.4147
G01 Y-2.2042
G02 X2.0857 Y-2.1381 I167.7055 J157.5456
G01 X2.0856 Y-2.1379
X2.0245 Y-2.0743
Y-2.0772
X1.8995 Y-1.9471
Y-1.9442
X1.7845 Y-1.8245
Mastercam X9/2017 Multiaxis for SolidWorks - Bobcad V29 3ax Pro 4ax Std.
