585,932 active members*
3,684 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > OpenSource Software > gcode ripper not starting at origin
    Aug 2017
    5
    I am attempting a pcb with cnc router. All is set up and after crashing my bit and breaking it, i set up the design size 2mm smaller for tolerence. When i run gcode ripper however it probes the first spot at X-0.1 and Y-0.6
    Why does it move and not probe at X0 and Y0? Is there a way i can get it to do this?
    Dec 2010
    226
    Re: gcode ripper not starting at origin
    It sounds like your design tool paths extend to a minimum X value of -0.1 and a minimum Y value of -0.6.
    G-Code Ripper can adjust the origin for you if you want it to. To adjust the origin you just set the Origin setting to Bottom Left ("Bot-Left") then the zero position will be at the bottom left corner of the design. Beware, if you do this and then do a subsequent operation like drilling the holes may not line up because you are asking G-Code Ripper to adjust the origin position.
    Scorch
    www.scorchworks.com
    Aug 2017
    5
    Quote Originally Posted by scorch View Post
    Ah. Another homer simpson moment. It goes to a negative because the software is using a cutting to that goes half a tool length beyond the design border to cut the board size you specified. Thanks i got it sorted
  1. G-code Ripper for newbie
    By Jocman in forum OpenSource Software
    Last Post: 08-25-2022, 06:14 PM
  2. Slotting with a ripper
    By jonnoCT in forum CNC Tooling
    Last Post: 05-04-2016, 07:27 PM
  3. the ripper - large area DIY CNC
    By MaxTheModder in forum DIY CNC Router Table Machines
    Last Post: 03-05-2014, 01:24 AM
  4. Ripper Mate!
    By rocket67 in forum Excitech routers
    Last Post: 07-30-2008, 06:41 PM
  5. Vm1 starting Gcode
    By copperhead4321 in forum HURCO
    Last Post: 02-20-2008, 09:13 PM
