585,978 active members*
4,397 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > How do you switch the parallel port to EPP mode in Linux?
Results 1 to 11 of 11
    Mar 2017
    926
    I'm using a PCI parallel port card with Linuxcnc but I can't get it working with my Gecko G540. I want to try switching it to EPP mode but I can't see any options for that anywhere.
    please can someone tell me how you switch to EPP mode with a PCI parallel port card?
    There is nothing in the motherboard bios which is no surprise as it's an add on card.
    Feb 2008
    644
    Re: How do you switch the parallel port to EPP mode in Linux?
    Quote Originally Posted by Goemon View Post
    Take a look at the parallel port driver manual page (by typing "man hal_parport" in a terminal window )
    Mar 2017
    926
    Quote Originally Posted by PCW_MESA View Post
    I did but I could find anything that I understood or anything that looked like it explained how to switch to EPP mode.
    The only mention is this:
    %5Burl=https://postimg.cc/8fTw0BQk%5D%5Bimg%5Dhttps://i.postimg.cc/8fTw0BQk/IMG-4544.jpg%5B/img%5D%5B/url%5D
    - - - Updated - - -
    Feb 2008
    644
    - - - Updated - - -
    Your manual page does not have this section?
    OPTIONS
    cfg="port_addr [type] [[port_addr [type] ...]"
    snip---------------------------------------
    The type parameter of the configuration string determines how
    the I/O bits of the port are used. There are four possible
    options and if none is specified will default to out.
    epp - This option is the same as setting to out, but can cause
    the computer to change the electrical characteristics of the
    port. (See USAGE below.)
    Mar 2017
    926
    OPTIONS
    I am new to Linux so I don't know what any of that means. I am used to Windows where I would solve this by putting the driver cd in and clicking "run".
    Is there any way you could run me through how to get EPP mode or is it too complicated to explain to someone with no programming or Linux experience?
    Feb 2008
    644
    Basically its means editing your hal file and replacing the word "out" with "epp" on the line that starts with "loadrt hal_parport"
    Mar 2017
    926
    Ok, that I understand. I'll give it a try.
    Thanks.
    Mar 2017
    926
    I tried changing the word "out" to "EPP" in the Hal file but now I can't seem to open Linuxcnc at all. I get this error:
    %5Burl=https://postimg.cc/XXJQtr37%5D%5Bimg%5Dhttps://i.postimg.cc/XXJQtr37/IMG-4545.jpg%5B/img%5D%5B/url%5D
    I tried changing it back but that didn't seem to fix the problem I created as Linuxcnc still won't open (and it did before). I am going to try reinstalling Linux.
    Mar 2017
    926
    After reinstalling Linux and going through the conf wizard again, Linux CNC started (but again no stepper movement). I tried changing "out" to "EPP" again and it broke Linuxcnc again. By broke I mean it won't open even if I delete all the config files and go through the wizard again. It requires a complete Linux reinstall to get back to where I was (which is nowhere).
    I am going to try a buffer card as a last attempt before I give up on Linux. The Gecko people have been of no help at all. They can't even recommend a parallel card that is guaranteed to work with their product. I just got the old "most parallel cards work with the G540 without issue" which is clearly not true. I've tried 4 and none work.
    Feb 2008
    644
    1: Everything in Linux and HAL is case sensitive so "EPP" is not likely to work (especially when the manual uses "epp")
    2: What editor did you use to edit the hal file? if you don't use a plain text editor, you will corrupt the file
    3. A re-install of LinuxCNC should really never be needed unless you are making major changes,
    its more likely you corrupted one of the configuration files somehow
    4: G540s need longer than specified step timing for 3.3V parallel ports I would always use at least 5000 (ns) for step times
    Jul 2003
    1754
    To add to what pcw has mentioned...
    5. The G540 only needs epp mode for the charge pump to work. It might be better to disable the charge pump on the G540 and see if you can get your steppers moving - then revisit the charge pump.
  1. Linux / linuxcnc can't see my parallel port card
    By Goemon in forum LinuxCNC (formerly EMC2)
    Last Post: 04-07-2019, 12:51 AM
  2. parallel port dead with pc-suggestions for purchasing usb/ethernet to parallel port?
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 08-19-2015, 11:32 AM
  3. no new computers have parallel?? experience on adding parallel port yourself?
    By teglberg in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2014, 07:18 PM
  4. parallel port or parallel universe
    By bruno34 in forum Taig Mills / Lathes
    Last Post: 04-15-2009, 04:58 PM
