585,991 active members*
4,725 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > Need Help V carving Chinese Characters
    Sep 2003
    1469
    VcarvePro (VCP) 8.5 Mach3 V2
    I frequently am called on to make Chinese plaques and such because my wife is Chinese and i'm a CNC hobbyist, all are made at no charge.
    The Chinese secretary will type and print the text out pretty large so it doesn't get ragged along the edges if I have to enlarge it in VCP.
    I scan the text in at a high resolution and save the file as a JPG, then import it into VCP "IMPORT BITMAP FOR TRACING" then click on "TRACE BITMAT-FIT VECTORS TO BITMAP". I then click on the center and delete it leaving the outlines. I notice that if I show NODES there are a lot, sometimes i will use the "CURVE FIT VECTORS" it reduces the number of nodes. But not sure if that speeds up the process or not.
    The VCP text utility has many styles of fonts, do you know if VCP would import Chinese Characters then Chinese could be typed directly into VCP and I am think it would result in better quality vectors and might have fewer nodes than imported JPG text.
    Can you offer any suggestions to improve V carving Chinese characters, I really would appreciate it.
    HH
    In Gilbert AZ
    Re: Need Help V carving Chinese Characters
    V Carve Pro uses whatever fonts are installed in Windows.
    If you can install a Chinese font in Windows, then you can use that in V Carve Pro.
    Sep 2003
    1469
    Thanks Gerry
  1. DNC missing characters!
    By Place2809 in forum DNC Problems and Solutions
    Last Post: 08-11-2009, 01:57 PM
  2. small characters on 0T
    By guhl in forum Fanuc
    Last Post: 05-20-2009, 08:13 AM
  3. Replies: 3
    Last Post: 04-01-2009, 06:25 AM
  4. Bad Characters
    By gplush in forum Haas Mills
    Last Post: 02-09-2008, 06:00 AM
  5. Relief carving small detailed parts - V-carving from greyscale image
    By ALAN2525 in forum Uncategorised CAM Discussion
    Last Post: 02-12-2007, 12:01 AM
