585,932 active members*
3,835 visitors online*
    Apr 2019
    Angry reinshaw probe problem
    I have a Mazak H600 m32 using a reinshaw probe using mazak software..works in manual mode and updates wpc but when you run can cycle such as xy center , it runs threw cycle fine but then just sits there with ready light lite and doesn't work and update wpc?? Checked all boards and macros and ok ..software issues?
    Jan 2016
    Re: reinshaw probe problem
    Martywr,
    I have the Reinshaw on a Haas, but expect that the macros are pretty much the same.
    Have you checked the memory locations for the probing result s to see if they reflect the correct data?
    Jul 2008
    70
    Had a probe act up. When someone changed the batteries they held the probe and change the settings.might want to look into that.
