Thank you for letting me in to this group. I am a new user to alphacam and I am having problems with a couple of things. the first thing is with the manual tool paths part of programming. I have recently started with a door manufacturer and I am modifying old parts by moving some geometry around and then reposting the program. but the manual tool path I can not get to work like the original part, or I can't figure out how the tool path was created. the next problem I am having is after modifying a part and then reposting it. i send it to the machine and the work offset is in the wrong spot. I did not change the position of the origin. so everything should have been ok with the part and program. is this a bug that I have to worry about in the future?
thank you for all of your help
