584,812 active members*
5,337 visitors online*
Results 1 to 9 of 9
    Apr 2019
    Question close geometry
    hey everyone,
    simple one for you,
    im very new to alphacam and cad type programmes,
    I have drawn a simple shape i need to machine, ive been able to apply a z level to it but i cannot set a material or or tool path because it says i need to close the geometry,
    as far as i can tell it is closed.
    What am i missing?.
    Tony
    Jul 2018
    6248
    Re: close geometry
    I'm not familiar with alphacam but CAM systems are sensitive to line gaps. Look at each intersection and check its contiguous. Some systems have a chaining function so if you select a line it will chain the lines connected to it. It stops at a gap so it's easier to find them. Look closely they can be hard to find (in plain sight).Peter
    Aug 2009
    1566
    Re: close geometry
    Welcome to the Zone.
    you can insert an Image (Screen shot) or Video of want you're trying to do with Quick Reply Tool Bar..
    Good luck
    Apr 2010
    89
    Re: close geometry
    You most probably also need to join the elements in your profile to create one continuous machinable profile using "Join" in the "Edit" Menu which should close the geometry.
    Click on "Edit" then "Join" then select (click on) each element you want to join then click on "Finish (ESC)"
    Elements won't join if an element does not start at the exact end of the previous element you will then need to use "Trim" or "Extend" before using "Join"
    Apr 2016
    841
    Re: close geometry
    Good advice so far. I've never used Alphacam, so my advice is more generic. Open vectors can be hard to find, as others have mentioned. Look at what you think are closed intersections and zoom way in for a micro closeup. Somethings that's the only way you can see them.
    if joining does not work also try common line removal. If you have two lines on top of each other it can sometimes cause problem and using common line removal will remove one of the lines.
    Nov 2013
    152
    Re: close geometry
    There is a function called " show breaks " which you will find in the view tab/display options (looks like two crosses on a broken geometry )
    It will put white crosses on your picked geometry where the start point is along with any broken elements. It`s a very useful function. Sometimes you might find a copied
    line which is underneath al line which is more difficult to spot.
    May 2011
    108
    Re: close geometry
    As long as You don't attach the drawing - we can only guess..
    Mar 2019
    27
    Re: close geometry
    Hello
    I am facing the same problem in sawing with arcs @ each end of the arc the saw is lifted & it cause a bad clean work on mirror how do I can make it continuously ???
  1. How to close this geometry?
    By vodjoa in forum Rhino 3D
    Last Post: 11-14-2016, 06:08 PM
  2. How close is close enough? (tramming)
    By bonesbr549 in forum Avid CNC
    Last Post: 10-21-2016, 02:02 PM
  3. Replies: 3
    Last Post: 03-07-2014, 06:26 PM
  4. Gecko - close to computer or close to motor?
    By andy_ck87028 in forum Gecko Drives
    Last Post: 11-28-2005, 05:39 AM
