584,842 active members*
4,196 visitors online*
Results 1 to 2 of 2
    Apr 2019
    PartKam gcode won't run on grbl Candle
    I used MakerCam to create gcode from an svg line drawing. The gcode displays and runs on the Candle simulator but, it gives errors at most of the G2/G3 instructions.
    It starts to run, goes to work origin and then to the staring point, the z goes down to a test height but then, it heads for machine home and hits the stops.
    Any suggestions as to why? The gcode has a comment line "created by PartKam"
    Its a small engraver using Woodpecker 3.2 and Candle .9
    Aug 2009
    1567
    Re: PartKam gcode won't run on grbl Candle
    G2 G3 Arc Centers.....incremental or absolute maybe set wrong
  1. PartKAM - free crossplatform 2.5d CAM
    By Jack000 in forum OpenSource Software
    Last Post: 07-16-2022, 09:48 PM
  2. GBR Candle - Heightmap checkbox disabled, why?
    By Chris01 in forum PCB milling
    Last Post: 07-12-2019, 06:34 AM
  3. GCode for GRBL based mini Pen Plotter
    By panoss in forum OpenSource Software
    Last Post: 01-18-2019, 10:05 PM
  4. Is it feasible to cut out letters from candle wax?
    By toeknee01 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-05-2015, 04:54 AM
  5. Candle cutting
    By interflexo in forum Material Machining Solutions
    Last Post: 01-15-2007, 10:45 AM
