585,973 active members*
4,031 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > Redsail Laser > Real Air Compressor Use Instead of Cheap Included Unit
    Apr 2019
    I'm looking for any tips and tricks in connecting an actual air compressor to my 60w Chinese laser unit. Instead of utilizing the small cheap air compressor that was bundled with it.
    Should I bother? Is the included unit enough? I've read that air assist is a hug advantage and the included unit is sub-par.
    Any help would be appreciated. I've searched YouTube and forums and found limited info.
    Chris
    Feb 2010
    155
    Re: Real Air Compressor Use Instead of Cheap Included Unit
    Search Youtube for a user named SarbarMultimedia. Russ has done a pretty detailed study of the effects of airflow, and tested two different sized air pumps on his 50W/60W laser.
    Episode 87:
    https://www.youtube.com/watch?v=OCVsMXw6yh4
    Episode 96:
    https://www.youtube.com/watch?v=m4Hh-8-9Tio
    Episode 116:
    https://www.youtube.com/watch?v=ZKC8Byc8y28
    If I interpret his results correctly, more air pressure helps for cutting, but there is a limit. However, he didn't test an actual air compressor (i.e. one with a tank), just two different sized aquarium-type pumps. I use a similar laser/pump on my 50W laser and don't have any issues cutting up to 1/4" material.
    For engraving minimal/no air assist produces cleaner results.
    Reading on SawmillCreek.org, some users have air compressors hooked up to their lasers, but it seems only to be required for cutting very thick materials.
    -robertk925
    Apr 2019
    The air pump that came with my machine died shortly after using it. I took it apart and found the bolt holding the rubber valve came loose. The inside was also full of crud from manufacturing. After a good cleaning and lubricating (and using Loc-Tite on the bolt that came loose) it runs much better than new -- a lot quieter and a lot more air output.
    Jun 2017
    6
    Hey, thanks for posting this, it answered a lot of questions for me!
    Quote Originally Posted by robertk925 View Post
    Episode 87:
    Episode 96:
    Episode 116:
    -robertk925
    Feb 2010
    155
    Great! Coincidentally, I have just started to add an actual air compressor to my 50W laser.
    I purchased this compressor:
    https://www.amazon.com/gp/product/B01LYHYHEA/
    This solenoid:
    https://www.amazon.com/gp/product/B07BW21Z5M/
    Some silicone tubing:
    https://www.amazon.com/gp/product/B07D11BSCR/
    Along with a bunch of air fittings and a water trap that I had leftover like this:
    https://www.amazon.com/gp/product/B002GQ3SUA/
    I have it all plumbed up, I just need to connect the solenoid to the Ruida controller. I will let you know how it works.
    -robertk925
