585,930 active members*
3,817 visitors online*
    Jun 2017
    369
    Weird surface on profile cuts
    Attachment 417532
    I just noticed this occurring on a job I just finished. I routed a total of 6 signs all had this type of finish on the edges.
    Material is kiln dried Maple.
    Bit is a new Onsrud 40-112 1/4" downcut
    Any help is greatly appreciated
    Gary
    Jan 2015
    194
    Re: Weird surface on profile cuts
    This is what the Separate Last Pass (offset) features in Vcarve and Aspire is meant to address. Usually on one of the sides of the Baltic Birch plywood I was cutting, I’d get a rougher cut and I’m sure it was due to the grain of the layers. So I added a separate .02” last pass with a depth of about .05” (modifying the pass depth so the first 2 passes went near full depth on the 3/4” plywood). Since adding this, all my cuts have been accurate and clean. You could also play around with which way you are cutting, climb vs conventional, as that could also impact cut quality.
    Edit - I was looking for the Vectric manual but I at least found this, which shows a picture of the feature.
    Vectric Forum • View topic - separate last pass
    You're getting deflection somewhere.
    I make a single full depth finish pass of about .02", at about 150ipm.
    I'd also recommend using a 3/8" bit, whenever possible.
  1. Tips for profile cuts
    By burbingus in forum Novakon
    Last Post: 01-13-2019, 10:50 PM
  2. Mach 3 making weird cuts, not following Gcode
    By justCNCit in forum Mach Software (ArtSoft software)
    Last Post: 04-06-2016, 01:24 PM
  3. 4th Axis Profile Cuts
    By echesak in forum Tormach Personal CNC Mill
    Last Post: 01-26-2016, 06:48 PM
  4. Weird profile cut problems with v21.6
    By Footprint in forum BobCad-Cam
    Last Post: 08-13-2014, 03:46 AM
  5. weird circle cuts....cant figure it out!
    By johndjmix in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-24-2012, 01:42 AM
