585,752 active members*
4,080 visitors online*
    Sep 2010
    135
    peck tapping on Robodrill --- Fanuc
    Hello all,
    I can't seem to figure out how to peck tapping on the robodrill Fanuc a-D21L iA5 control.
    my other Fanuc does pecking tapping with G94 M29, with PITCH X RPM = FEED...
    but on this machine I wanted to just use the pitch...
    example below
    (M7x1 XXXX TAPRH)
    M29 S300
    G98 G84 Z-10. R10. Q3. F1.
    I find it way simpler because 90% of the jobs are in mellimeters.
    Anyone please tell me what would be the proper way of doing this pecking tapping cycle?
    thanks
    Dec 2012
    395
    Re: peck tapping on Robodrill --- Fanuc
    Add G95 before the M29 S300 command.
    (M7x1 XXXX TAPRH)
    G95
    M29 S300
    G80
    G94
    M30
    Regards,
    Heavy_Metal
    Sep 2010
    135
    Thanks Heavy_Metal
    What I don't like about the G95 on this machine is, the single block works a little weird, it stops in every single cycle. It stops at every peck.
    It got to be a parameter to change this...
    Thanks and cheers to you!
    Dec 2012
    395
    Check your Parameter-Manual for Rigid Tapping.
    For the 0i-D series par. 5200 and more.
    Par. 5200 #6 (FHD)
    FHD Feed hold and single block in rigid tapping:
    0: Invalidated
    1: Validated
    Regards,
    Heavy_Metal.
  1. New Fanuc Robodrill or 7000 hour robodrill with all the bells and 4th axis?
    By The_R1_Kid in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2018, 01:26 PM
  2. Fanuc 0TB peck rigid tapping
    By guhl in forum Fanuc
    Last Post: 07-15-2018, 05:19 PM
  3. Peck Tapping
    By aldepoalo in forum Haas Mills
    Last Post: 06-06-2016, 06:32 PM
  4. 17-4 peck tapping
    By Delw in forum Haas Mills
    Last Post: 12-11-2010, 02:43 AM
  5. peck tapping
    By qmas99 in forum Surfcam
    Last Post: 01-17-2008, 12:26 PM
