585,938 active members*
3,255 visitors online*
Results 1 to 5 of 5
    Jan 2014
    10
    Lightbulb Benchtop/ Jeweler's precision lathe build
    Hi guys, I'm a mechanical design engineer, me and my colleagues will be working on a precision lathe which has a spindle runout of 0.0001", and has a swing distance of 6", it's a small lathe that can be mounted on your desk but can turn various materials from cupper and aluminum to titanium... so considering the precision aspect of the lathe, what should we take into consideration while designing that, specially it's our first time to design lathes? what are your opinions so we don't make costly mistakes?
    Mar 2015
    409
    Re: Benchtop/ Jeweler's precision lathe build
    If you need this kind of precision (0.0001") than you also need a constant room temperature, a solid table (not a desktop), guides without play, special lubrication, special tool holders, special chuck/collet, an educated measurement technician and a lot of high precision measurements tools that are periodically calibrated!
    Are you sure you really need this?
    Jan 2014
    10
    Quote Originally Posted by hfjbuis View Post
    Yes, I need that ! What do you think about the spindle?, what should be the main things that I should consider?.
    And yes you're right about the foundation of the machine to be as rigid as possible, I said that just for you to imagine it.
    Aug 2016
    132
    The spindle is one thing I would not try to DIY with the accuracy you want. You can certainly get a shaft to the right dimensions without much equipment, but do you have any way to grind a tube, flip it 180, and grind the backside concentric to the front?
    For the amount of work involved, I would save my pennies and buy a spindle from Dunham that is garunteed to have 50 millionths runout. Their 2 bearing 5c model would be under $3k.
    A cartridge spindle also makes other aspects of construction easier. The headstock doesn't need tolerances as tight, and vertical alignment can be done with shims. Horizontal alignment can be done with the usual push pull bolts.
    Apr 2004
    5737
    If you could live with .0002" runout (or maybe better) you might try the 5c headstock that Taig makes for its lathes. It's turned on its own bearings for concentricity. See Taig Tools - Desktop Milling Machines and Lathes. If you're just looking for a headstock, it would cost a lot less than $3k. We sell these parts at a discount, if you're interested.
    Andrew Werby
    Website
  1. What happened to Benchtop Precision
    By Upnorth4 in forum Benchtop Machines
    Last Post: 08-08-2019, 10:32 PM
  2. benchtop precision
    By taiwanluthiers in forum Benchtop Machines
    Last Post: 07-02-2018, 03:04 AM
  3. Looking info about small precision CNC Lathe to build!
    By joseluisz in forum Uncategorised MetalWorking Machines
    Last Post: 04-05-2017, 07:43 AM
  4. A benchtop cnc lathe build
    By S_J_H in forum Vertical Mill, Lathe Project Log
    Last Post: 09-26-2015, 02:08 PM
  5. 80/20 benchtop lathe build
    By LeeWay in forum Vertical Mill, Lathe Project Log
    Last Post: 06-15-2015, 01:35 AM
