585,676 active members*
5,326 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Memory Lost After Sitting Idle for a Few Weeks
Results 1 to 6 of 6
    I was out of the country for a few weeks and did not power up the VMC for about 3-weeks.
    When I powered up, all memory and machine settings were lost???
    Not difficult to re-enter everything and all files are saved on the Calmotion SD card, but somewhat of a PITA.
    Is this normal, expected after sitting idle, or is something possibly wrong.
    Any input appreciated.
    Thanks, Mark
    Aug 2009
    1570
    Re: Memory Lost After Sitting Idle for a Few Weeks
    Age my friend main reason for Battery failures most likely....It was good to be young once..
    What Year and Model Control do you have?
    Sample battery click below.
    ITS: Tadiran TI2100 Battery, ELE-0082
    Feb 2007
    171
    Sir, you will need to replace the battery on your CPU board. It is in slot #5 of your control rack. Desolder the battery on the board and solder the new one back in. You will lose everything again so make sure it all is saved. Once the battery is replaced, run a zero memory procedure on the control then re-enter your parameters, programs and backlash values. If you shoot me your email address I can send you the Zero Memory Procedure. We also have the battery in stock. $15.
    FadalCNC Tech Support
    ok..., seems like any easy fix. the machine is a little over 10-years old (2007), so makes sense that the battery is shot.
    thanks,,,
    Let me know if you need the zero memory procedure. It is a good idea to run this after a battery replacement. You can email [email protected] and request the Zero Memory Procedure and I will make sure you get it.
    Quote Originally Posted by FadalCNC_Com View Post
    i did perform the zero memory reset when i upgraded the memory card and will follow the same procedure.
    just ordered battery and will install soon!
    thanks for assistance...
  1. Lost of memory Leadwell MCV 760 AP
    By adangros in forum Fanuc
    Last Post: 04-21-2022, 05:15 PM
  2. Replies: 2
    Last Post: 06-18-2016, 02:36 PM
  3. Z axis servo has been getting hot sitting at idle
    By williamsmotower in forum Charter Oak Automation Support Forum
    Last Post: 08-28-2015, 03:44 AM
  4. Brother TC312 Memory lost
    By asstec-italia in forum Fanuc
    Last Post: 02-24-2014, 01:32 AM
  5. My CNC memory is lost
    By claudiu220405 in forum Uncategorised MetalWorking Machines
    Last Post: 07-25-2011, 06:00 AM
