585,729 active members*
4,422 visitors online*
    Jan 2008
    83
    Broaching on hawk200
    We have a hawk200 w/ A2100 control and have the PH Horn tools to internal broach, but not sure which way to program it. We are producing belt pulleys with a 35mm bore and key way for an 8x10 key. I have the start, as I can orient and lock the spindle, get it to run a couple passes with G1 to test. Which canned cycle do most use to produce the multiple passes without programming each move? Usually program with our CAM software and only use the drilling, reaming cycles. Looked through the manual but not sure if the std ID turning cycle or ?? Previous owner said he had used a face grooving cycle? Any direction would be appreciated.
    Jan 2008
    83
    Re: Broaching on hawk200
    just a followup; got through the job with standard code; all the fixed cycles I tried would alarm out as the spindle was not running. I got surfcam to produce the moves and changed the spindle code to what we needed to orient and lock it in the post.
    Sep 2012
    106
    What code did you use for orienting the spindle? I have a job with an A2100 control and have no idea how to lock the C axis in place
    Jan 2008
    83
    Quote Originally Posted by Third-Gen View Post
    I will look when I get to the shop tomorrow. I believe M19 is the spindle lock and has to be used with a linear move.
    Jan 2008
    83
    PM'd the code
  1. Hawk200 no spindle feedback
    By kccrusher in forum Cincinnati CNC
    Last Post: 06-17-2017, 07:35 PM
  2. broaching
    By helpmeout in forum MetalWork Discussion
    Last Post: 06-19-2012, 03:49 AM
  3. L5/L7 Broaching
    By Ovrclck350 in forum CNC Swiss Screw Machines
    Last Post: 05-23-2012, 07:39 PM
  4. Broaching Job, Broaching head
    By unlock in forum Tormach Personal CNC Mill
    Last Post: 05-15-2010, 11:30 PM
  5. Broaching
    By dcalp in forum FeatureCAM CAD/CAM
    Last Post: 10-01-2008, 02:53 AM
