585,670 active members*
4,654 visitors online*
Results 1 to 3 of 3
    Apr 2011
    68
    V 29 oem post
    I am looking to add on a laser to my cnc router . I see that many people use the spindle feed to turn on / off laser , but how do I turn it off during rapid moves between tool paths , so it does not mark the piece ??
    Ed
    Jun 2008
    1838
    Re: V 29 oem post
    Ed
    Well, I don`t know much about laser cutters so I just had a look at the BC Laser PP and it looks like the On/Off and Z retract for rapid moves seems to be done automatically with the following areas in the PP,
    50. Line rapid move Z - Z retract
    n,lpw_cutter_off
    n,lpw_gas_assist_off
    n,lpw_shutter_closed
    51. Line feed move Z
    output_part_number
    n,"( MSG,PIERCE ",shape_number," "
    In between these quotes it should have a colon : and a bracket ) but the Zone is putting a smiley in there !!
    n,lpw_shutter_open_closed
    n,lpw_gas_assist_type
    n,lpw_gas_assist_on_off
    n,lpw_cutter_on_off
    n,dwell
    750. Laser-Plasma-Waterjet Cutter Width Prefix? "D"
    751. Laser-Plasma-Waterjet Pierce Height Z Location Prefix? "Z"
    752. Laser-Plasma-Waterjet Cutter On Code? "M702"
    753. Laser-Plasma-Waterjet Cutter Off Code? "M703"
    760. Laser-Plasma Gas Assist On? "M710"
    761. Laser-Plasma Gas Assist Off? "M711"
    762. Laser-Plasma Gas Assist With Air? "M712"
    763. Laser-Plasma Gas Assist With Oxygen? "M713"
    764. Laser-Plasma Gas Assist With Oxyacetylene? "M714"
    765. Laser-Plasma Shutter Open? "M715"
    766. Laser-Plasma Shutter Closed? "M716"
    767. Laser-Plasma Pulse Frequency Prefix? "F"
    768. Laser-Plasma Power Setting Prefix? "P"
    769. Laser-Plasma Torch Height Control Prefix? "T"
    it may be of some help to you but if you haven`t already got one you will need to download a Laser PP from BC to suit your machine control, I have Zipped up the one I have here for you to test, it is for all versions V26 through V31 so should work!!
    Regards
    Rob
    Apr 2011
    68
    Re: V 29 oem post
    Thanks Engine Guy , I'll give it a try .
    Ed
  1. Replies: 3
    Last Post: 11-30-2016, 07:28 PM
  2. Replies: 0
    Last Post: 07-24-2016, 08:43 AM
  3. Special post for presentation! Laser manufacturers/dealers post their contacts here!
    By Litografa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-22-2010, 07:23 PM
