585,969 active members*
4,488 visitors online*
Thread: g41 g42
Results 1 to 14 of 14
    Feb 2019
    76
    g41 g42
    Why in this program does not work g41.1 ? No compensation for tool radius!
    soft - TNG
    G90G80G21G49
    M6 T1
    G41.1 D1.5
    G43 H1 G0Z50.0000
    M3 S24000
    G0 X0 Y0
    G1 Y100
    G1 X100
    G1 Y0
    G1 X0
    M5
    M30
    Re: g41 g42
    What is G41.1?
    Most controls use G41 D#
    Mar 2017
    1311
    Re: g41 g42
    There is a bug and G41 is not implemented in latest TNG version.
    Feb 2019
    76
    Re: g41 g42
    really want to swear.
    will it be corrected?
    Feb 2019
    76
    Re: g41 g42
    And your motherboard has very, very big problems with noise immunity, why did you not do LAN in MK3 / 4? wanted to save money? very bad decision!
    Feb 2019
    76
    Re: g41 g42
    If you only knew how much I suffered with your controller and TNG
    Aug 2009
    1573
    Re: g41 g42
    What is G41.1?
    G Codes
    I wondered what G41.1 and G42.1 were also.
    Feb 2019
    76
    Re: g41 g42
    Thank you for understanding )
    Mar 2017
    1311
    Re: g41 g42
    We are working with mathematicians from Irnas institute on new G41 implementation. It should be better that any other existing and will include advanced features such ad dogbones and start/end tangent for cutting internal shapes. And most important - no more non logical leadin/leadout moves.
    Regarding gerber files - this import module was never meant for pcb cutout. But I understand that keepout layer could be used for this and I'll try to add new "Cutout" option.
    @ger21
    G41.1 is from RS-274 specification (used in LinuxCNC). It is for cutter compensation with dynamic diameter. See this:
    G Codes
    Feb 2019
    76
    Re: g41 g42
    When is the update planned?
    Sep 2011
    110
    Re: g41 g42
    I'd thought it's a postprocessor issue. The G41/G42 offset is a basic feature of control.
    The G41/G42 isn't needed in NC code if the software could calcualte the compensation, then the issue could be avoided temporarily.
    Feb 2019
    76
    Re: g41 g42
    PlanetCNC. Still have a question. Why, after losing the connection, are the working coordinates reset, while all other coordinates are not reset? Can I make the working coordinates remain the same?
    Feb 2019
    76
    Re: g41 g42
    what the heck is that?
    I just write Z10 (to move the spindle) and press the enter, and it will produce some garbage? before this was not!
    Dec 2008
    3109
    Quote Originally Posted by Anriro View Post
    If you look to see the active g-code list .... G02 is active... it requires MDI code to perform an arc
    ... you need to add G00 to MDI input to place it in rapid.. or G01 for a linear feed move ie G0 Z10. or G1 Z10. F1000.
