585,975 active members*
4,886 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Drip Feed / DNC? --- Conquest T42 with Fanuc 18T controller
    Feb 2019
    38
    I have a Hardinge Conquest T42 with Fanuc 18T controller. There is clearly no switch to put it into tape mode. Is there soft key for tape mode?
    I have the RS-232 hooked up to a Titan USB, which works great for moving files. I now have some programs that I can't get to run because they are too large.
    I thought I had seen "tape" somewhere on one of the control soft keys. I'm certain I have seen "punch" for outputting files. There must be a way to get this thing into tape mode. What's the scoop???
    Thanks!
    Aug 2009
    1573
    Re: Drip Feed / DNC? --- Conquest T42 with Fanuc 18T controller
    https://www.easydnc.com/cnc-machine-...s/fanuc18.html
    Might help...might not is your case,
    DJ
    Feb 2019
    38
    Quote Originally Posted by machinehop5 View Post
    DJ
    Thanks!!! I've tried all of this. The key is I can't find "Tape Mode" anywhere. Switch nor soft key.
  1. Drip Feed M (T) Plus Controller
    By scot1911 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2022, 12:54 PM
  2. Fanuc Controller in Drip Feed Mode
    By CastleWorks in forum Bridgeport / Hardinge Mills
    Last Post: 10-12-2017, 11:57 PM
  3. Conquest 42 - Drip Feed
    By jonesturf in forum Hardinge Lathes
    Last Post: 03-09-2016, 07:40 PM
  4. Replies: 0
    Last Post: 05-05-2010, 01:43 PM
  5. Replies: 9
    Last Post: 04-28-2008, 06:10 PM
