585,729 active members*
4,575 visitors online*
    Mar 2019
    10
    CRP with Masso
    Just starting tuning a new CRP 48x96 pro machine. I'm using Masso as the controller. As such, I cant use the CRP xml file for Mach 3. Masso needs to know is the amount of linear travel per motor rev. I'm using the NEMA 23 with 3/8" shaft. From the information I have, I think I'm looking at 1.1519 inches travel on x and y per rev. Can anyone familiar with the CRP R&P drive setup confirm? Thanks much!
    Re: CRP with Masso
    The info is on their website.
    3.14159 per rev.
    PRO Rack and Pinion Drive, NEMA 23 | CNCRouterParts
    Mar 2019
    10
    Re: CRP with Masso
    I saw that. However, there is a 3:1 (or 2.73:1) reduction. So it's not 3.1459 but 3.1459 divided by 3 or 2.73. That's what's not clear.
    From the website:
    The R&P system is based on a pinion with a 1" pitch circle. The total linear distance traveled per revolution of the pinion is thus 3.14159". With the 3:1 reduction, this means that the distance traveled per motor revolution is 3.14159 / 3, or 1.0472". If you have a stepper with 200 steps per revolution, this means you have 200 / 1.0472" = 190.9861 steps per inch, or 0.005236" per step. With 10x microstepping, you would have 1909.861 steps per inch, or 0.0005236" per step. For the optional 3/8" pulley, this number changes to 1736.237, as the motor pulley is slightly larger.
    Re: CRP with Masso
    Yes, I should have read the next line.
    They should be a little more clear, as you would have 3.14159/(60/22), or 3.14159/3.727272 = 1.1519173063162575207696359072025
    Mar 2019
    10
    Re: CRP with Masso
    Thanks Ger21, I think that's it. Seems to work great.
    Dan
  1. Masso controller
    By Dean448 in forum Controller & Computer Solutions
    Last Post: 04-13-2019, 09:21 PM
  2. No Masso Fans here ?
    By mongoose in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-30-2019, 02:55 PM
  3. HELP! AdleePower BL2 and Masso
    By slowhitEJ1 in forum Spindles / VFD
    Last Post: 06-23-2018, 08:06 PM
  4. MASSO and Z
    By Matt-y in forum DIY CNC Router Table Machines
    Last Post: 03-12-2018, 09:41 PM
  5. MASSO and the KRMx02
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 01-04-2018, 03:18 AM
