585,982 active members*
4,644 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > New member - Spindle setup Optimum BF 46 with UCCNC
Page 1 of 2 12
Results 1 to 20 of 26
    Apr 2019
    8
    Hello,
    I'm a new member and i hope someone could help me or point me i the right direction.
    I recently bought a used Optimum BF 46 Vario from 2007 fitted with stepper motors from optimum controlled by optimum controller IV.
    I use UCCNC together with UC100 motion controller and Fusion 360 for CAD/CAM.
    I´ve got the x,y,z axis to work but i don´t know how to connect the spindle to the controller IV and setup with UCCNC or if even is possible.
    Is there anyone here with a Optimum mill that uses Controller IV or anyone who got a good guess.
    Info on the optimum controller IV:
    The Unit has:
    1 X parallel ports named port 1 (25pin)
    9 pin connection plug for a three axis point of origin
    4 X slots for the stepper motor cards (I am using 3)
    1 X relay port, potetial free relay output (8 outputs/pins)
    Pin assignments for the DB 25 male is
    Pin Application Description
    1 RELAY Switch output eg (motor on)
    2 Direction X axis
    3 Cycle X axis
    4 Direction Y axis
    5 Cycle Y axis
    6 Direction Z axis
    7 Cycle Z axis
    8 4th Axis
    9 4th Axis
    10 Free
    11 References switch Z
    12 References switch Y
    13 References switch X
    14 RELAY Output eg coolant
    15 Reference switch 4th axis
    16 - 24 Free
    25 OV DC, Earthing
    The 9 pin connection pins are as follows for the reference switches
    1 X1 Machine point of origin port 1 X Axis
    2 Y1 Machine point of origin port 1 Y Axis
    3 Z1 Machine point of origin port 1 Z Axis
    4 ROUND TABLE
    5 +12V DC
    6 X2 Machine point of origin port 2 X Axis
    7 Y2 Machine point of origin port 2 Y Axis
    8 Z2 Machine point of origin port 2 Z Axis
    9 OV DC
    I would like to controll the spindle speed, direction and on/off from within UCCNC.
    Greetings from Sweden.
    May 2009
    33
    Re: New member - Spindle setup Optimum BF 46 with UCCNC
    So i do this with the c76 board from cnc4pc. But on a KBIC controller. On a g0704.
    Chances are high that you have a KBIC clone controller inside the spindle control box.
    If so, yes you can control spindle speed this way. I chose only a forward direction but it may be doable to do both. Please advise if a KBIC controller is inside your motor box.
    Apr 2019
    8
    Thanks for the response.
    How do i know if i have a KBIC clone controller?
    Best Regards
    May 2009
    33
    KBIC-125 (9433) DC Drives Chassis https://www.amazon.com/dp/B007ZQLJM0..._6P3VCbMZS9BBP
    It will look like this for the most part. Hear sink for the mosfets and this mounting pattern. Take a pic and post it please.
    Apr 2019
    8
    Here is a pic.
    Best Regards
    May 2009
    33
    That is much fancier than a KBIC. It probably has an integrated LCD for spindle speed.
    Is optimum still in business? And any chance you can find a part number on this board?
    I’m guessing the thick wires on the left go to the motor, and that it is a 4 conductor motor?
    Nov 2005
    222
    Apr 2019
    8
    Yes it has a display for spindle speed, Optimum is still in business but are not very helpful (dosen't answer).
    Yes i got a hold of a manual and the Part nr is 03021303201
    I also got a hold of the wiring diagram. se pic
    I took a pic of the motorplate.
    Best Regards
    Apr 2019
    8
    I'm sorry i wrote Controller VI but it is the VI i've got.
    Thanks anyway.
    May 2009
    33
    Interesting. That is a 2.2KW closed loop BLDC drive.
    X3 is motor drive power.
    X7 is the hall effect sensor for the motor.
    Are the X* connections marked on the main board?
    It says X6 is going to a 12 pin or more connector - would that be the bundle of pink wires?
    And does the motor control box have a general purpose connector on it anywhere? One that goes back to Controller VI?
    Apr 2019
    8
    Okey,
    I don't think the X connections are marked, but i will have a look tomorrow.
    Yes X6 is most likely the bundle of pink wires, i'm attaching two pics.
    I'm pretty sure that the motor controllbox doesen't have a general purpose connector on it, I will have a extra look tomorrow.
    The only cabel that goes from the motor controlbox to the Controller VI is the emergency stop (the grey cable)
    I guess it's via the relay outputs on the controller VI i should controll the spindle (No 7 in the picture of the controller)
    May 2009
    33
    So here is my analysis of whats going on so far:
    1. Your Controller VI may not control the spindle at all. Nothing. It may only want to control the axis motion.
    2. You have a standard on/off switch, estop mechanism as well. We can ignore these for now.
    3. You will need to figure out exactly what your reversing switch does. Does it send a control signal to the board saying "forward/rearward motion" or does it actually swap the polarity on the motor inputs. Seems like it might be control signals based on how the motor is wired up. You should look up its part number if you can find it, and check its behavior with a meter to see what it does.
    4. The hardest thing will be dealing with the potentiometer that controls spindle speed. It may have its resistance measured by the RPM display board and send a digital signal back to the controller to adjust the spindle speed.
    Can you send a picture of the back of the RPM display?
    Thanks for your patience.
    Apr 2019
    8
    I've had a extra look.
    The only cabels that is going in and out of the controlbox is:
    In: main power
    Out: Cabels to the motor, emergency stop, cabels to the display for fine feed of spindle sleve
    There is no general purpose connector or similar.
    The X connections are marked on the bord, some are almost not visable anymore. Se pics of X3, X6 and X7
    I've taken a pic of the back of the LCD-display
    I should be thanking you for you're patience!
    Best Regards
    May 2009
    33
    So controlling spindle operation will be doable via analysis of your reversing switch.
    This switch will most likely have a voltage or ground that is switched when you turn it. This will be hooked to relays used to control spindle direction. You may need a third relay to do spindle on-off.
    The other part of it is that potentiometer. You should check what’s it’s input voltage is and what happens when you turn it. It may be possible to use a PWM spindle controller hooked to that switch to change the speed.
    May 2009
    33
    https://cnc4pc.com/c6-variable-speed-control-board.html
    This is the control board I use for this.
    May 2009
    33
    Also a point of annoyance - your controller may closed loop operation. Or the encoder may only drive the LCD.
    The mechanism I use does not support closed loop - and you cannot do closed loop straight off of the UC100 unit with the encoder feedback. That means no rigid tapping. Only the UC300 is powerful enough.
    Jul 2010
    180
    Ok forget the KBIC controller!! These drivers are used on the optimum Vario lathes and is useless for what you want.
    Depending on your setup you can drive the board with your controller. I use pico systems breakout boards. In my case I made a board to replaced the switches with relays (see pic), but If you don't want to make this board, you can buy the C6 board which will do the job.
    Attached is a circuit diag for you.
    Cheers
    Stephen
    Attachment 425242Attachment 425244Attachment 425246
    Jun 2015
    943
    Quote Originally Posted by vectorsc View Post
    The UC100 has spindle encoder setting so it can do rigid tapping. It does not have the spindle PID setting though what the UC400ETH has.
    Jul 2010
    180
    Just to clarify things. The feedback from these motors is a tachometer... it is not an encoder, so forget that idea about rigid tapping. The Optimum board being discussed monitors speed and will adjust torque according.
    You can do G84 tapping with this motor and in the video you will notice the torque kick in when speed drops.
    https://youtu.be/FR-_Kr4iZms
    Mar 2017
    5
    Quote Originally Posted by FastFarmer View Post
    Cheers
    Stephen
    Hi Stephen, picture appear to be no longer available. Would appreciate it if you could upload them again. I will be in Victoria in April/May this year and would love to catch up with you to see how your BF46 is running
Page 1 of 2 12
  1. New MODBUSEZ SetUp Plugin For UCCNC
    By Dan911 in forum UCCNC Control Software
    Last Post: 10-21-2023, 04:34 AM
  2. Uccnc - trial for uc100 + mach3 setup
    By robertspark in forum UCCNC Control Software
    Last Post: 07-09-2016, 05:35 PM
  3. UCCNC units and setup
    By skcncx in forum UCCNC Control Software
    Last Post: 12-30-2015, 04:46 PM
  4. UCCNC software installation and setup tutorial
    By dubble in forum News Announcements
    Last Post: 08-08-2014, 01:01 PM
