586,005 active members*
4,974 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Using terminals DRV & UPF on Huanyang FVD
    Nov 2005
    222
    I am trying to use either the DRV or UPF terminal as my spindle-at-speed signal to LinuxCNC via a Mesa 7i76. When I check across the DCM and DRV or UPF with my meter is reads a an open circuit. I tried wiring it like this and it does not work. Any idea how to wire these? I have PD050=01 and PD051=05 so both should be on when the spindle is running and at speed.
    I'm using a 10k resistor instead of the 2k picture. The 7i76 side works if I short the leads that I'm hooking to DCM and DRV together.
    Attachment 417844
    John
    Jul 2014
    Quote Originally Posted by rcheli View Post
    Attachment 417844
    John
    Hola amigo.
    Pudiste encontrar el problema?
    Estoy en la misma situación
    Nov 2005
    222
    Re: Using terminals DRV & UPF on Huanyang FVD
    Mine is working. I'll check after work today to see how I ended up wiring it.
    Nov 2005
    222
    I looked at the wiring on my Huanyang Inverter. I have the 24V terminal connected to the FB terminal. Then the DCM & FA terminals are connected to the 7i76. I have the DCM terminal connected to the TB1 Field Power Ground and the FA terminal connected to TB6-10 (This could be any free Field Input terminal.)
    This is my HAL setting.
    # ---Setup spindle at speed signals---
    net spindle-at-speed <= hm2_5i25.0.7i76.0.0.input-10
    John
  1. Huanyang VFD +5V & +24V Terminals
    By Ozzwinkle in forum Spindles / VFD
    Last Post: 04-20-2014, 02:48 PM
  2. G203V Pluggable Terminals Loose
    By JerryBurks in forum Gecko Drives
    Last Post: 10-24-2012, 03:45 PM
  3. Haas Breaker Terminals
    By CNCOX in forum Haas Mills
    Last Post: 03-17-2010, 06:25 PM
  4. Capacitor w/4 connetion terminals
    By TravisR100 in forum CNC Machine Related Electronics
    Last Post: 01-22-2007, 01:51 AM
  5. Drive terminals
    By Don C in forum CNC Machine Related Electronics
    Last Post: 01-23-2005, 01:26 AM
