585,753 active members*
3,685 visitors online*
Results 1 to 11 of 11
    Aug 2006
    5
    BT30 or BT40 ?
    Hi all,
    I am considering buying chevalier VMC 1418
    They have BT30 and BT 40 models
    My work mostly 6061,7075 and stainless steel , small run prototyping works
    Which model suitable : 15k rpm BT 30 or 10k BT40 ?
    I appreciate any comment / suggestion
    Jon
    Jan 2004
    3154
    If you are working the aluminum with small dia endmills you will REALLY want the 15K spindle. If not using too many small cutters go with the 40 taper. 30 taper is not rigid enough for heavier work and the tooling is less common.
    www.integratedmechanical.ca
    Aug 2006
    5
    Thanks for your info, I think 3mm endmill is the smallest , should I go with 40 taper?
    May 2005
    674
    No question, go with the 40.
    Jan 2004
    3154
    For me - I agree with Zumba
    BUT
    I have done some large aluminum parts with small diameter cutters. For instance a 3mm cutter carbide with AT coating should run at 38,000 RPM. I have a 10,000 RPM spindle. My machine cutting time was somewhere around 70 hours on this part. If I could have met SFM I would have saved 50 hours on that part. At 15,000 RPM I would have saved 17.5 hours.
    You need to consider how much aluminum and how often small cutters.
    I will only buy 40 taper or bigger and my next machine will have a 15K spindle.
    Aug 2006
    5
    I am thinking about spindle heat developed by 15k spindle.
    running it more than 8 hours, will be there any problem because this model has no spindle chiller
    Jon
    Oct 2006
    51
    don't forget to balance holders running that high of an rpm.
    recommended balancing is over 15,000 rpm, but definately over 20,000 or you are going to have spindle issues.
    and don't just buy balanced holders and put tools in, they need to be balanced together at those rpms. it's amazing how much the force on the spindle increases with an unbalanced holder as the rpms go over 15,000.
    Jun 2007
    48
    Bt 40
    No doubt, you should get the biggest diameter spindle available or you are going to run into chatter problems. Even with 15K spindles, they are not fast enough to do justice to the small diameter tooling today. You also mentioned SS. You certainly don't want to machine SS with a 30 taper. BTW, any time one runs over 8K rpms, you should balance the toolholders. You will get better spindle performance, better tool life since you have minimized the potential for tool runout and better surface finishes. With small diameter tooling, with a balanced toolholder at 2.5 g, and indicated in, it should work very well for you.
    Sep 2005
    66
    HSK is better
    If you could get HSK taper it would be wayyy better. HSK63A would be sweet--
    Jun 2007
    48
    Bt40 Hsk63
    You ain't gonna get no HSK from Chevalier!
    Quote Originally Posted by kimhan View Post
    Hi all,
    Jon
    I feel bad for anyone new reading this that gets the idea a bt30 is insufficient. We have r8, bt30, and bt40 In our shop and while it’s obvious they get more rigid in that order a bt30 is perfectly capable in machining stainless. heck our r8’s cut right through it and any harder materials, tool steels, etc fine when feeds and speeds are adjusted appropriately. Yes rpm reduces work time and so on but it feels a little biased and misinformative to someone who may be newer to the industry and on a budget. anyways whatever a person purchases if they have realistic needs for their budget nearly anything can get the job done. It’s a rich mans business for sure. be willing to start somewhere and you can always trade or sell equipment when it’s time to upgrade. Perhaps 10 years ago took holders were more rare but today they’re everywhere and can be had fairly cheap. So this message is for anyone new who comes across this that they can know there are other considerations besides having the biggest or best. Do whatever it takes to get the task done within your budget.
  1. bt30 spindles
    By thump in forum Tormach Personal CNC Mill
    Last Post: 05-21-2014, 02:20 AM
  2. Looking for a BT30 Spindle
    By xtwalt in forum Uncategorised MetalWorking Machines
    Last Post: 11-20-2012, 10:10 PM
  3. BT30 Spindle
    By dirtridn2010 in forum Tormach Personal CNC Mill
    Last Post: 05-07-2012, 11:19 AM
  4. BT30 tool holder DXF
    By Master_CNC in forum Mechanical Calculations/Engineering Design
    Last Post: 11-14-2007, 03:03 PM
  5. BT30 and R8 tools
    By cncuser1 in forum CNC Tooling
    Last Post: 10-01-2007, 09:42 PM
