585,938 active members*
3,189 visitors online*
    Apr 2009
    220
    DIY Large Sheet Cutting Machine
    Hi guys,
    I have built my first CNC machine 4 years ago and hopefully it still works.
    Now what I am wondering about is if I could be able to built a large sheet cutting machine for melamine and MDF sheets. I am not interested in building the hydraulics that pull and push the sheets, but mainly I need to know how I could built the base of it, then put the moving cutting blade machanism under the machine and finally connect it with linear guide attached to a motor with a driver.
    Any ideas if this idea can be implemented and if there is any trader that sells moving cutting blades would be really appreciated.
    Thanks in advance.
    Apr 2004
    5737
    Re: DIY Large Sheet Cutting Machine
    Are you talking about a moving table-saw blade, or a router of some sort?
    Andrew Werby
    Website
    Apr 2009
    220
    Quote Originally Posted by awerby View Post
    I am talking about a moving saw blade, just like the moving blade in the large sheet cutting machines.
    Thanks.
    Apr 2018
    37
    So a DIY Beam Saw?
  1. Machine cutting different across the sheet
    By Herptastic in forum Calibration / Measurement
    Last Post: 03-24-2016, 06:11 PM
  2. metal sheet laser cutting machine fiber cutting or mix laser cutting
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-19-2015, 09:03 AM
  3. best choice steel sheet cutting machine fiber 500w laser cutting machine
    Last Post: 07-22-2015, 08:46 AM
  4. Replies: 2
    Last Post: 08-13-2014, 11:34 PM
  5. Cutting up a large sheet of acetron gp
    By TT350 in forum Glass, Plastic and Stone
    Last Post: 12-08-2007, 09:12 PM
