585,877 active members*
3,351 visitors online*
Results 1 to 9 of 9
    Sep 2009
    88
    Delta NC300 contoller setup master slave
    Hello
    tried to search for some threads on Delta CNC solutions: Delta NC300 controller with ASD-A2 drives and motors (750W) but in vain.
    We tried to setup the 4 axis, drives and motor work, but as the Delta manuals (for controller and drives) are so thin, could not find a way to set the master/slave parameters and make it work.
    Not sure if anyone familiar with the controller, but worth trying to see if anyone has an idea on how it works.
    So in the NC the axes are defined, and parameters for the A axis slave to Y axis is set. Still, the when moving Y, A motor does not move. When tryi ng to move A, it works.
    No error is popping up.
    I tried to contact Delta customer service but in vain.
    I assume the controller adopts standard setup. So suggestions on how other c0ntrollers are set might work.
    here the link to NC300 controller manual.
    http://www.deltaww.com/filecenter/Pr...N_20160309.pdf
    Any input appreciated.
    Marius
    Sep 2009
    88
    Re: Delta NC300 contoller setup master slave
    SOLVED
    the firmware was too old, and update solved the issue instantly
    Mar 2008
    4
    Hello dear I have the same control and I have some problems has the firmware and if you can give it to me, I would appreciate it.
    Quote Originally Posted by nicubila View Post
    SOLVED
    Sep 2009
    88
    Quote Originally Posted by ananayas View Post
    did you solved it?
    Mar 2008
    4
    did you solved it?
    I have not been able to fix it. Can you please send the firmware and information to me at [email protected]. I would appreciate it very much
    Mar 2008
    4
    Nicubila .Help please
    Sep 2009
    88
    only now I managed to get the file, hope this is the one.I cannot upload it as original *.pkf, so you have to change the extension.
    this is the instructions i received. But because it is 2 years ago when it was installed by someone else on my nc300, i cannot say if this is really how it works.
    Marius
    ps: I managed to make work the homing for absolute encoders in case you need it. it is a simple file, few lines
    Mar 2008
    4
    Nc300 expiration time
    Hello
    can anyone help nc300 .expiration time
    https://youtu.be/NG7jR7sYHI8
    Attachment 490716
    Sep 2009
    88
    Hello
    Attachment 490716
    So can you work with it or not?
  1. Slave axis is not synchronized with master
    By Antrac1t in forum Machines running Mach Software
    Last Post: 02-07-2022, 04:50 PM
  2. Master and slave electronic gearing
    By rainman in forum Stepper Motors / Drives
    Last Post: 12-22-2010, 02:53 PM
  3. CNC Master and Slave problem
    By cambridgecnc in forum CNC Machine Related Electronics
    Last Post: 12-01-2010, 04:04 AM
  4. master-slave servos
    By js412000 in forum Servo Motors / Drives
    Last Post: 03-09-2007, 07:36 AM
  5. Master and Slave servo
    By Builder in forum Servo Motors / Drives
    Last Post: 11-02-2004, 03:55 PM
