Ran into an issue with my mill turn. My swap axis switches spindle control between the mill turn and the main vertical spindle. Because of this, both are following the same spindle pulley settings which i need set to 24000 rpm max for the main spindle. This means my step/dir controlled mill turn spindle needs to have it's max velocity set to 24k rpm for the units to work correctly with the spindle pulley settings even though I don't run it above 3k rpm. With a minimum acceleration setting (about 4 seconds to max rpm) this takes my mill turn spindle from 0-3k in a half a second, which is too much and
Usually faults the servo drive, especially on the deceleration.
How can I get around this and set the acceleration lower than the minimum it's allowing? Not sure why there's a limit there in the first place. Should be able to accelerate as slow as you want.
