585,922 active members*
3,931 visitors online*
Results 1 to 3 of 3
    Mar 2008
    114
    Parameter description 6t
    Does anyone have a digital copy of the parameter descriptions for fanuc 6ta? I want to set backlash comp and g30 and need to know which parameters and what values are accepted.
    Thanks!
    Sent from my G8343 using Tapatalk
    Aug 2009
    1573
    Re: Parameter description 6t
    Mar 2008
    114
    Update - called fanuc America and the support guy gave me the parameter numbers over the phone! Backlash is 115 & 116, and G30 is 159 & 160. Just in case anybody else wanted to know
  1. Super Max Machining Center 60 Parameter Description Required
    By prakashyaah in forum Drilling- and Milling Machines
    Last Post: 09-09-2014, 04:15 PM
  2. Super Max Machining Center 60 Parameter Description Required
    Last Post: 09-09-2014, 09:15 AM
  3. What machine description to use?
    By mx2 in forum Mastercam
    Last Post: 07-01-2011, 06:14 AM
  4. encoder description
    By guhl in forum Fanuc
    Last Post: 05-23-2010, 09:59 PM
