Re: please, i need a " trick " : how to align a long drill on a misaligned turret ?
hi hfjbus, i was given a piece of aluminium from a metal can, which is 0.10thick, and had rough edges, so i did not used it
so far i did not know about the 0.01 "kitchen" type; are these for sale ?
about copper, thanks for the tip, but i wish to avoid the "preparation" time i mean, even if it works, i preffer to avoid it
Plastics like nylon absorb water (coolant) and get thicker
yes, this is what i am afraid of ... but, in that area where i put plastic, it is not exposed directly to coolant, so, if it degrades, i guess that it will not be sudden, but in time, and this may be detected by regular alignment inspection ( like once at 2-3 days eg ); that's my bet so far
Other types like PTFE (Teflon) keep getting thinner under pressure. You could use POM that doesn't absorb water and is pretty stable under pressure
is there laminated teflon or pom, like 0.05 foils ? i don't know / kindly
