I have been working on replacing my Huanyang 220v Inverter for the last few weeks and after going through 2 exchanges with Huanyang I have gone back to the original Inverter I had it was the "HY" series ,
Now I have the spindle running but I made some changes in mach3 when I was trying to get the "GT" series to work with my setup. Now I have the spindle running but it will not turn off from mach3 anywhere and because of the way it works with RS485 there is no control from the Inverter key pad either. I have looked at all the settings but I am can not tell what is wrong. I did see in the general config there is a location for M1 (optional?) for turning off and it was checked but I don't see any M1 in my gcode .
When a program is running and if I press STOP motors stop moving gcode stops running but the spindle stays on and nothing will turn it off but the emergency switch I had installed for the 220V. not even the emergency stop switch will turn off the spindle and that is not good.
Another thing I did notice is that there was always a readout for the RPM DRO but not this time? the input (gcode) DRO is filled but when spindle is running there is a 0 in the DRO ? Could the issues be related?
I ran a Operator- Check Config and I found this
Pin for an Output found as not pins 1 - 9, 14, 16, or 17. Unless using ModBus, this is wrong.
///////////////End of OUTPUT Signals Check///////////////////////
At this point I will try anything
Pat
