585,722 active members*
4,286 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Dxf imported into solidworks
    Dec 2009
    30
    When I import a dxf file into solidworks it comes in as a million little sketches as opposed to curves. These small sketches really do a number on my waterjet machine when I try to cut it out.
    Does anyone know how to "clean this up" or prevent it from happening?
    Sent from my SM-N960U using Tapatalk
    Mar 2008
    683
    Re: Dxf imported into solidworks
    When you import go to your settings and import as "one sketch" and not as 3D curves.
    Another thing is what is exporting DXF. at least in autocad you can export as a single polyline or break it down. Usually what i do if I'm stuck with a million little lines is I will import the DXF in to one sketch, then make another sketch right on top of it and draw it out myself.
    Sep 2019
    4
    Import file DXF/DWG to Solidworks: Autocad to Solidworks
  1. Replies: 0
    Last Post: 07-19-2016, 05:57 PM
  2. Replies: 0
    Last Post: 07-19-2016, 05:56 PM
  3. Webinar: New VisualMILL for SolidWorks Integrated CAM Solution for SolidWorks
    By Craig_Preston in forum Trade Shows / Webinars / Other Events
    Last Post: 07-16-2009, 01:03 AM
  4. Replies: 0
    Last Post: 07-16-2009, 12:43 AM
  5. best cam for lathe? input being imported solidworks models
    By Jamison in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-01-2009, 04:16 PM
