585,761 active members*
4,126 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > WS55-180 is blinking red in groups of 7
    Sep 2017
    9
    I have just tried to test my diy CNC engraver. No luck.
    Its WS55-180 has a steady green LED and a red LED blinking in what appears to be groups of 7.
    Supply voltage is 48.1v, and motor coils are all 4 ohms.
    The gap after the 7th blink appears to be a bit longer, but could be my imagination.
    Does a list of error codes exist, and if so, where?
    May 2016
    Angry Re: WS55-180 is blinking red in groups of 7
    Hai I starting with a WS55-180 driver and a adjustable power supply. In most cases the driver is flasing the red light. Sometimes the spidel is starting. But
    when I stop the motor using the pot meter the motor is not starting again. When I switch off the power and wait 1/2 hour it is some times working again.
    I have checked the wiring and the voltage level but all is ok.
    When I stop the spindel using the pot the red let is starting blinking and when I try to restart the spindel it is not working
    It seems that the driver is not starting and the red les is blinking continuously
  1. WS55-220 BLDC Driver Mains Connection
    By ajayre in forum CNC Machine Related Electronics
    Last Post: 08-11-2018, 04:43 PM
  2. re groups in cam V29
    By woffler in forum BobCad-Cam
    Last Post: 02-23-2017, 01:41 AM
  3. X4 Blinking When Turned On
    By dpaish in forum Syil Products
    Last Post: 10-26-2012, 05:42 AM
  4. Pro E 'blinking' problem
    By John@CRDM in forum PTC Pro/Manufacture
    Last Post: 03-05-2009, 12:21 PM
